A/C performance specification?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by etyler88, Aug 8, 2006.
  1. etyler88
    etyler88 etyler88
    450
    Dover, DE
    My A/C works fine but the air it blows out is not nearly as cold as the A/C in our 93' Camry. So I am wondering if there is a problem. I assume on the MAX COLD setting there is a specification on what the temperature difference should be between outside air and the A/C output air, I can just use a thermometer at a A/C vent to check. Assuming A/C is set to outside intake. (the A/C is still satisfactory when I operate on recirculate)
    Does anybody know if there is a factory spec for the temperature difference?
  2. raslin07
    raslin07 New Member
    Mesa, Arizona
    <div class='quotetop'>QUOTE(etyler88 @ Aug 8 2006, 09:19 AM) [snapback]299631[/snapback]</div>
    Back in 93 they used R-12 it was a colder refrigerant most newer cars are not as cold as the old ones they use R-34 but set a thermostat in to the vent and check the tempature it shoud be at least a 25 deg differance to be operating correct
  3. etyler88
    etyler88 etyler88
    450
    Dover, DE
    <div class='quotetop'>QUOTE(raslin07 @ Aug 8 2006, 12:44 PM) [snapback]299650[/snapback]</div>
    Mucho Gracias
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Something else to consider, which you may already know, the Prius uses a variable speed compressor for the A/C. The synchronous A.C. motor runs the compressor only as fast as it needs to to maintain the desired temperature. Of course on MAX COLD it should indeed be maximum cold.
  5. richard schumacher
    7,664
    1,045
    United States
    Running on recirc gives cleaner air and, when the outside air is hotter than inside, it's more efficient .
