Front License Plate Bracket
Discussion in 'Gen 2 Prius Main Forum' started by romad, Aug 4, 2018.
  1. romad
    romad 2004 Prīus Base Former Owner (Sold 13 May 22)
    320
    57
    Prescott, AZ
    My wife has the Prius at our other home in Arizona so I can't look and check for myself.
    Does the bracket only have mounting ports for the top two holes on a plate or does it have them for all four plate holes?
    I know the back plate mounting only uses the top plate holes.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Theres only 2 dimples on the front bumper.
    Raytheeagle likes this.
  3. romad
    320
    57
    Prescott, AZ
    OK, I just found a Toyota bulletin for installing the the front bracket and it only has mount points for the top two plate holes.
    Question has been answered.
  4. romad
    320
    57
    Prescott, AZ
    Our Prius came with the bracket already mounted to the bumper. I needed to know if there were two or four PLATE mounting holes on the bracket for a project I'm working on. Now that I know there are only two PLATE mounting points I can continue with my project.
    srellim234 and Raytheeagle like this.
  5. romad
    320
    57
    Prescott, AZ
    OK, need some more help since I'm 700 miles away from the Prius. What size bolts/screws are used for the plate attachment? IIRC, they are machine but I don't know if they were metric of SAE. What nuts are used, captive speed nuts?
    I checked a Toyota parts website but they only showed the bracket and the screws for mounting the bracket to the bumper cover.
