Gentex 453 on Prime Premium
Discussion in 'Prime Accessories and Modifications' started by blanka98, Aug 14, 2018.
Tags:
  1. blanka98
    blanka98 Junior Member
    17
    Socal
    2013 Prius Plug-in
    Hey guys,
    Just purchased my Prime Premium two weeks ago (switching from 2013 Plug-in) and I am amazed on the improvements except for the 4 seater and smaller trunk space. I've always installed rear view mirrors with homelink on all my cars but I noticed that the new Prime with the lane sensing camera gets in the way. So here is a quick solution if you already hardwired the power/acc/ground for the rear view mirror.
    Why spend $500 for the longer neck version from the dealer when you can do the following:
    1. Purchase a Gentex mirror from eBay for $50
    2. Purchase a Brandmotion 5000-SPCR Windshield Mirror Spacer $55
    3. Dremel the current cover to adapt the extension
    4. Assemble everything back and you are done!!!!
    Here are some images:
    Mirror spacer mounted
    2. Original cover with pencil markings
    3. Dremel
    4. Place the cover back and you are done!!
    GTprii likes this.
  2. Insighter
    Insighter Active Member
    409
    282
    SoCal
    I don't understand. What does this allow you to do? Is that a camera lens you made the cut-out for?
  3. blanka98
    17
    Socal
    2013 Prius Plug-in
    If you purchase an used Gentex mirror from ebay or an older gen prius mirror, the neck of mirror is too short because the camera cover gets on the way. They do sell a new OEM (by gentex) with longer neck for our Prius but it costs $500. My solution was just to add a mirror extension and then trim the camera cover to fit. Hope this makes sense :)
  4. Insighter
    409
    282
    SoCal
    Thank you for respondiong, but I guess I wasn't clear. I mean what does mounting this Gentex mirror do for you? Why did you want to do it?
  5. blanka98
    17
    Socal
    2013 Prius Plug-in
    Ohh....I can't live without the Auto-dimming mirror and Homelink feature =)
    Insighter likes this.
  6. justice37
    justice37 Junior Member
    Oregon
    2019 Prius Prime
    it is very nice mod. Can you tell me how you wire them? Is there any plug or need to wire then all the way down to fusebox?
  7. blanka98
    17
    Socal
    2013 Prius Plug-in
    I ran a fused wire from the fuse box through the pillar.
    iPad ?
  8. justice37
    Oregon
    2019 Prius Prime
    Thanks! I just realized that there is no "IG+ (or ACC)" wire available on ceiling area. I should run it down to the fuse box.
  9. blanka98
    17
    Socal
    2013 Prius Plug-in
    I used this to get power from the fuse block. Please keep in mind that you will not be able to put the fuse cover back. I just left in my glove box.
    Nilight 12V Car Add-A-Circuit Fuse Tap Adapter Mini Atm Apm Blade Fuse Holder-10 Pack, 2 Years Warranty
    iPad ?
