New style prius traction battery
Discussion in 'Gen 3 Prius Main Forum' started by RAM2940, Aug 12, 2018.
  1. RAM2940
    RAM2940 Junior Member
    va. beach, va
    Could some post the link to the company that is creating the new prius traction battery, I found it searching on here a couple weeks ago, now cannot find it. Its the battery that's suppose to be like the honda insight battery. Thank you
    52,379
    never heard of it, do you mean gen 4?
  3. Fred_H
    Fred_H Misoversimplifier
    560
    485
    28
    Germany
    I think RAM2940 probably means this: NewPriusBatteries.com | Home
    Instead of prismatic (rectangular shaped) cells, like the original Prius battery, it uses cylindrical cells packaged lengthwise into modules, like the Honda batteries.
    Hi RAM2940, the owner of this company, who is also a PriusChat member, is known here as 2k1Toaster and has started some threads about his batteries here:
    Prius Battery Replacement Kit (GenII/GenIII) with NEW custom cells
    Prius Battery Replacement (GenII) Like you've never seen - NEW Cylindrical Cells
    But there are also a couple other companies with similar batteries.
    FuelMiser, bisco and Raytheeagle like this.
  4. bisco
    52,379
    thanks fred! i had a senior moment there.:oops:
    Fred_H likes this.
  5. RAM2940
    va. beach, va
    Yes that is the sight I was looking for, thank you
