Hesitate and shiver
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ashaq Qurbankiel, Aug 16, 2018.
  1. Ashaq Qurbankiel
    Ashaq Qurbankiel New Member
    Auckland
    Can anyone help i bought 2010 Toyota prius new generation, about a month ago it is done 137k, now when i give acceleration up hill then hold the acceleration at the half press level it hesitate and engine shiver, a mechanic told me to replace air filter and spark plugs, i did but it is still the same
    52,397
    welcome!
    could be dirty throttle body, oxygen sensors, egr circuit and intake manifold. does she burn any oil?
    possibly a weak battery cell causing the engine to work harder.
    start by checking for trouble codes with tech stream. if none, read through gen 3 maintenance and troubleshooting threads for clues.
    all the best!(y)
  3. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Fuel filter.
  4. Ashaq Qurbankiel
    Auckland
    Thanks for your suggestion, but there is no light on the dashboard to indicate the issue
  5. Ashaq Qurbankiel
    Auckland
    Thanks i was talking to the mechanic about the fuel filter, but he said the car has only been driven 137k so it can't be, plus no code light on the dashboard
  6. bisco
    52,397
    sounds like you're sool then.:unsure:
  7. Mendel Leisk
    41,921
    When I search the Repair Manual for "hesitation", this is the first hit, in the troubleshooting section:
    I'd start with the easiest, maybe Throttle body cleaning (@NutzAboutBolts has a video on that, pinned at top of 3rd gen maintenance sub-forum), and cleaning the Mass Air Flow sensor (MAF sensor). Use MAF sensor cleaner, it says it on the can, nothing else. CRC make one, and there's YouTube video on how to do it.
    I'd second all @bisco's suggestions, with the miles you have the EGR in particular is probably getting clogged. Again, see the aforementioned @NutzAboutBolts thread for EGR cleaning.
    Have the plugs been changed; it was due at 120K miles IIRC.
    NutzAboutBolts likes this.
  8. Ashaq Qurbankiel
    Auckland
    Thanks good suggestions yes spark plugs have been replaced,
  9. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Fuel filter can go bad sooner than 137K. You believe what mechanics says? :ROFLMAO:
    Raytheeagle and jerrymildred like this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    If it happened suddenly, and you'd recently bought gas, that would scream "fuel filter." If you hadn't just bought gas, that doesn't rule out the filter, but it does open up the other options.
  11. Pdaddy
    Pdaddy Member
    160
    49
    Did you solve the issue?
    SM-G960U ?
