USB outlet iPhone flickers on/off upon insertion
Discussion in 'Prime Main Forum (2017-2022)' started by MagnetoBlue, Aug 15, 2018.
  1. MagnetoBlue
    MagnetoBlue Junior Member
    74
    31
    Burbank, CA
    Hey guys, I have an iPhone cable connected to my USB outlet that’s charging my iPhone 6 Plus but upon initial insertion it flickers on/off around 3-5 times before it stays on consistently. Anybody have the same issue?
  2. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    Yep mine does the same thing. We kept on thinking it was the cable. Now I know it’s happening to someone else.
    MagnetoBlue likes this.
  3. alexcue
    alexcue Active Member
    346
    311
    So Cal
    yep, what iOS are you running? I'm running 12 beta, and I've noticed it doing it. Hadn't seen it before.
  4. MagnetoBlue
    74
    31
    Burbank, CA
    I’m using iOS 11.4.1 and it’s been like this since I bought it. I’m wondering if there’s a fix?
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    NO.
    Because that likely is happening because the two systems are "talking" to each other and the car is "logging" any files it finds on the phone......like music files.
    If the blinking light is the ONLY indication you have of that going on, count yourself lucky.
    My wife's phone causes a message to pop up 4 or 5 times complaining that it can't find any "media files" before it finally gives up.
  6. jaqueh
    341
    199
    San Francisco
    I’m also running 12 beta but I’ve had this issue since somewhere in the 11s.
  7. burnout8488
    burnout8488 Member
    124
    81
    Endwell, NY
    I'm pretty sure this has nothing to do with the operating system our phones are running.
    The car pulses the charging circuit 3 times when an iPhone is plugged in. It charges extremely slow, if at all. Then the headunit will crash if I take a long drive. It's a known issue and Toyota seems content with the trash infotainment they've been putting in their cars for years. (Entune)
    Carplay would seemingly fix all of this, but Toyota's stubbornness prevents that from happening.
  8. Njner
    Njner Junior Member
    2018 Prius Prime
    +1 for this issue. I changed cables and it helped.
