Traction battery electric cooling fan.
Discussion in 'Prius c Main Forum' started by Javierz0509, Aug 14, 2018.
  1. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    My question is when the traction battery electric fan starts blowing in cool air from the cabin where does it get exhausted to?
    51,255
    an exhaust vent below the 12v battery.
    AliPK likes this.
  3. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    i didn't notice any vent at the end of the funnel
  4. bisco
    51,255
    it goes to the hybrid battery case, then exhausts out of the car. maybe location of the c exhaust is different.
  5. dubit
    dubit Senior Member
    850
    538
    Indiana
    2016 Prius c
    I've wondered about this myself. I can't seem to find any diagram, video, print etc. Not that I needed to know for anything, but it was / is a curiosity.
  6. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I recall someone on here a few years back had pictures with the interior out. It showed that the exhaust vents to the trunk area of the car, not outside the car. But I could be misremembering.
  7. bisco
    51,255
    should be in the service manual
  8. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    yeah it dont go outside of the car is what i notice it goes out the trunk area..Wth?
  9. bisco
    51,255
    how did you notice that?
  10. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    pulled the back seat out, also it hit me when i had to replace the HV battery a while back i took out all the air channel to remove the battery.
  11. bisco
    51,255
    no wonder the battery stays so hot.
  12. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    So how to make hot air out of the car?
  13. bisco
    51,255
    drill holes in the bottom of the hatch pan?
  14. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Run your AC, if the cabin air into the battery is cool, it will come out cool... ish.
    jerrymildred likes this.
  15. AliPK
    AliPK Member
    71
    30
    Pakistan
    I had aqua and I remember it going up to the trunk and that was it!!!
  16. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    This is taken from the NCF (New Car Features):
    Vincent
  17. Mendel Leisk
    40,687
    They don't put a label on this, but I think it's the air exit?
    AliPK likes this.
  18. AliPK
    AliPK Member
    71
    30
    Pakistan
    Why are the arrows pointing inwards???
  19. Mendel Leisk
    40,687
    Good point.
    Assuming the system is similar to regular Prius, air is sucked in by the rear seats, run through the battery, then exits on the side walls in the hatch area. The exits are flaps, hidden on the outside, behind the rear bumper.
    I'm thinking that grill is similar function, but yeah, the arrow direction is not jiving, lol. Maybe the graphic was done on a hung-over Monday? It's the one element in the picture that, while it appears to be part of the process, it has no label.
  20. dubit
    dubit Senior Member
    850
    538
    Indiana
    2016 Prius c
    Glad to see someone found this diagram! :)
