Warning light on
Discussion in 'Gen 2 Prius Main Forum' started by zzyzx, Aug 10, 2006.
  1. zzyzx
    zzyzx Junior Member
    96
    2026 Prius Plug-in
    The yellow ((!)) light was on today on my commute into work. I can't call the dealership for another hour or so. What kinds of things cause that? Should I be concerned that my brand new car already has a major problem?
  2. zzyzx
    zzyzx Junior Member
    96
    2026 Prius Plug-in
    <div class='quotetop'>QUOTE(Zzyzx @ Aug 10 2006, 06:18 AM) [snapback]300748[/snapback]</div>
    Never mind; it was the tire pressure light. I didn't turn the page in the manual to see that. Now to figure out how to correctly gauge my tire pressure.
  3. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    I was just gonna post that... head to your local auto parts store (preferably in someone elses car - it's bad to drive on a flat/low tire). they should have tire pressure gauges there for under 10 bucks. FWIW, i prefer the digital ones, and have had one stashed in every car i've owned since day one. I also keep a portable air compressor in the car. i believe it was 20-30 bucks, and plugs into the outlet in the car. It also has an integrated flashlight and warning flasher, should you be pulled over with a flat at night.
    anyways, the gauges are real easy to use - just remove the cap on the tire, and push the gauge in, it'll give you a digital reading of the pressure. you can then pump it up to where you want (checking occasionally to get a feel for the rate of increase in pressure so you don't go too high). A lot of people here prefer the tires at 42/40 (being the recommended pressure on the sidewall of the tire), but toyota recommends 35/33 (located on frame of the car inside the passenger door), probably more for the comfort of the ride than fuel mileage or even tire wear.
  4. zzyzx
    zzyzx Junior Member
    96
    2026 Prius Plug-in
    <div class='quotetop'>QUOTE(eagle33199 @ Aug 10 2006, 07:12 AM) [snapback]300776[/snapback]</div>
    Higher number for the front tires or the rear ones?
  5. sl7vk
    sl7vk Member
    518
    Salt Lake City
    <div class='quotetop'>QUOTE(Zzyzx @ Aug 10 2006, 10:23 AM) [snapback]300787[/snapback]</div>
    Front.
