HV battery terminal strap / bridge
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by danielz000, Aug 22, 2018.
  1. danielz000
    danielz000 Junior Member
    27
    London
    Active
    Hi guys,
    After a month of cycling batteries I'm about ready to reinstall...
    One question before I do though...
    When taking the battery apart i recall a metal strap over the two HV leads. If i recall each of the leads had a metal outer casing, I assume these had a voltage but maybe they were insulated...
    Can anyone confirm if this strap goes over the metal outer case and the case are insulated or she whether the strap was rather close to the metal but not actually touching them?
    Cheers
    Dan
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,415
    3,286
    Madison, Wisconsin
    Lay the orange cables in place.
    Put the strap on to the two upward facing bolts. It will align itself.
    danielz000 likes this.
  3. danielz000
    27
    London
    Active
    Cheers Eric
