Brake lights and stopping at junctions
Discussion in 'Gen 4 Prius Main Forum' started by Ampletum, Aug 27, 2018.
  1. Ampletum
    Ampletum Junior Member
    Greater Manchester UK
    Excel
    I can't believe I have had my Prius for three months, it seems like just yesterday I bought it. I am getting so used to driving an automatic I forget myself when I drive my wife's puddle jumper. One of my pet hates is when the guy in front of me stops at traffic lights he sits with his foot on the brake pedal meaning I get the full glare of his high intensity brake lights. I now realise that this is more or less the default option when driving an automatic unless you engage the P option each time you stop. What is the consenus on this? Do you sit with your foot on the brake pedal and in the D position ready to drive away? Or do you engage the P position each time you stop at lights? Or maybe I am just being an old fusspot and should just enjoy my Prius and not worry about the guy behind me. I look forward to hearing your thoughts.
    RCO likes this.
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Even with a manual, I use the brake the whole light.
    (I still find my self shifting to D (from D) at a light, it has only been 9 years since I owned a manual)
    WilDavis and RCO like this.
  3. GadgetVirtuoso
    Fort Worth, TX
    2018 Prius
    Most cars don't have an electronic transmission and in order to get to P have to move a lever. Even so, I sit there with my foot on the brake, always have, even when I drove a manual.
  4. dbf
    dbf Member
    78
    86
    NE Ohio
    As far as I'm concerned, It's always been a good habit to keep you foot on the brake at any temporary stop especially in hilly areas like around where I live. For one thing, you don't want to be inadvertently rolling forward or backward and for another, it gives another visual cue to other drivers behind you that you are stopped and won't be moving until you take your foot off the brake.
    KokomoKid, Tande and The Professor like this.
  5. Mendel Leisk
    41,749
    @Ampletum why not describe your location less cryptically, say Sheffield, United Kingdom?
    Anyway: stopped at lights, I'll vote for just step on the brake pedal.
    #5 Mendel Leisk, Aug 27, 2018
    alanclarkeau likes this.
  6. StarmanUK
    StarmanUK Junior Member
    Essex, UK
    Business Ed. Plus
    To be fair its a Royal Mail postcode which is anything but too non-cryptic ;)
    Honestly I've now got used shifting into N, and using the pedel handbrake when parked for shorter periods when I want to be able to move off quickly (need to be aware that this will not charge the battery but is also useful to remember when going into automatic car washes). Simple case of shifting to D and removing the handbrake. This means you don't need to touch the foot break.
    RCO and Mendel Leisk like this.
  7. Mendel Leisk
    41,749
    To be fair: clicking on his postal code actually pops up a Google map with location flagged, at least on my pc.
  8. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    At a stop light/sign I simply step on the brake pedal until it's safe to go. The only time I put our car in park is waiting for a long train at a RR crossing.
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Danger alert!!!
    In pull-through car washes you MUST be in ready mode and select neutral.
  10. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    Another one for holding on the brake pedal here, driven automatics for years and it has always been my default option.
    Tande and dbf like this.
  11. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Similar to me, if stationary for a long time, (wreck, train, construction) I do put it in P and run the 4 way flashers until some car stops behind me, then turn off the flashers, assuming they will take steps not to be hit. For some of you there will always be a car behind you, for others it may be minutes.
  12. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    This question has come up many times before. Forget what I do, I wish the guy in FRONT of me with those BIG BLINDING BRAKE LIGHTS would put HIS in park! I've had to lower the sun visor at night because some vehicles have such bright LED brake lights. Mostly SUV's.
    Buy I don't fault the driver. I actually wish my little Prius had much brighter (and larger) tail lights and brake lights. This looks pretty wimpy, especially in the day time. I keep saying, the Gen3 Prius has the BEST brake lights. They immediately get my attention! But the Gen4 stinks! (Toyota trying to save money again.)
    Mendel Leisk and RCO like this.
  13. Ampletum
    Excel
    Point taken, I have changed my location so it ie easier for our overseas members to understand. Where are all the rest of you that hate BIG BRIGHT RED LIGHTS shining in your face at stops?
  14. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Hello, I'm another one.
  15. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Depends - but I do more or less the same as I do with a Manual;
    • if there is nobody behind me, I keep my foot on the brake pedal - that way they see I'm stopped when they come over the crest or whatever;
    • if there is someone behind me, and I know I'm early in the light cycle and it'll be red for a while, I select "P", but, I have to be alert to go for the brake and "D" quickly when the light goes green.
    Starship16 likes this.
  16. Starship16
    1,348
    1,455
    Beach Christmas
    I do the same. I use the "P" button many times during the day. My foot gets tired at these long red lights. Some seem to be 5 minutes. (It also saves wesr & tear on the brake light bulbs.)
    Sometimes we will have a serious accident on the freeways. Traffic can be completely stopped for two hours. Nobody is moving. But all these people leave their engine running and their lights on. Some of them still have their foot on the brake. (I can understand if they need the AC running in the heat. But at least they could turn their lights off, and put it in park.)
  17. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    When it was level and I was driving a manual in my last car, I let my foot off the brake to give my right knee a rest.
    Now, I'm with the rest of the sheep, sit there with my foot on the brake unless it is a train I'm waiting for or a REALLY long light.
    There's nothing that says you have to stare at his brake lights, you old fusspot! ;)
    Just teasing a bit, yeah, some brake lights are super bright. (I'm thinking especially about BMW) It's not for sitting at lights, it's for when it's pouring rain and you're driving 70 mph and can barely see in front of you.
  18. Salamander_King
    Salamander_King Senior Member
    11,020
    8,955
    New England
    I keep my foot on brake while stopping on the road, be it on the intersection or stop and go traffic. I can't remember what I did with a stick shift, being some 30+ years ago, but I am quite certain I kept a foot on a brake as well. Of course, back then there was no car with center light, so someone doing that to me didn't bother me much.;)
  19. Starship16
    1,348
    1,455
    Beach Christmas
    And don't get me started about people who drive around in pouring rain, or fog, with NO lights on! I see many Prius cars that are totally blacked out. Who said Prius owners are SAFE drivers? HA!
    - Buford T. Justice
    #19 Starship16, Aug 28, 2018
  20. VFerdman
    VFerdman Senior Member
    1,186
    1,216
    Western Massachusetts
    I am having a hard time believing I am reading this. I believe it's part of every drivers' education program to instill the fact that keeping the brakes on at stops is part of safely operating a vehicle. Say you are sitting at a light in neutral and there is a pedestrian in front of you and you get rear-ended. That's a disaster! If you are sitting at a light and in P or N with parking brake and there is a situation where you have to move out of the way quick! The delay of putting the car in drive may mean a difference between non-issue and disaster.
    Just keep your foot on the brake and car in D when at stop lights or stop signs or whatever. It's not that complicated that it has to even be discussed! It's basic safety 101.
    I am pretty sure that you would fail a driving test in most of free world if you did anything but keep your foot on the brake at stops.
