Power steering problem
Discussion in 'Gen 3 Prius Main Forum' started by TrinidadPrius, Aug 5, 2017.
  1. TrinidadPrius
    TrinidadPrius New Member
    Trinidad
    My Prius gen 3 power steering failed. No power assist. Can you help please. These are the codes I'm getting 1501973159515.png
  2. kobear18
    kobear18 Junior Member
    92
    san francisco
    where is the power steering fluid anyways ? I want to change that too
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    There’s none;).
    Its Electric (y).
  4. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    This appears to be a power steering loosing communication with the power steering ECU.
    I have had a similar experience with a hybrid Highlander last year. Steering was so had, it took the customer tremendous amount if energy to navigate em.
    Long story short, reoakxrd the steering ECU and did a calibration, with tech stream, get it didn't work. Replaced steering rack, after making sure the U,V, and W wires on the electric steering motor connected straight up to the steering ECU had no open circuits. That still didn't fix the problem.
    Finally!!! I had to trace the steering DC DC converter, down to the HV pack contractors (unit of HV relays), and realised that the connector was not connected in there.
    Connected that back, and got steering assist back.
    In your case, might be the same.
    1.If you got another steering ECU, try swapping em
    2. Do a voltage test on the steering ECU circuitry to the U,V,and W, wires to the electric steering motor.
    3. So you hear any cluck noise when you turn the steering? I think there are TSBs or so for some of the problems?
    4. Have a the stream handy though.
    Let's know how it goes.
    Dxta
  5. ChapmanF
    18,556
    A Highlander Hybrid probably does have a higher-voltage steering motor, with its own converter served from the main battery.
    I don't think a Gen 3 Prius II does though. Still 12 volt steering there, I think.
    May as well try reoakxring anyway, I guess. What could it hurt?
    -Chap
  6. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Well, that was an experience I shared. Probably, might be similar, I don't know. But its worth nothing
