What Sealed/Non-OEM 12v Battery are You Running?
Discussion in 'Gen 2 Prius Technical Discussion' started by bailor, Aug 31, 2018.
  1. bailor
    bailor Junior Member
    17
    Southern California
    I know the optima battery is pretty much the only 12v battery that meets OEM standards, but I also know some of you are running sealed deep cycle 12v batteries. Which ones are you running and would you recommend? What are your experiences?
    52,393
    actually, there are for or 5 oem options.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  4. bailor
    17
    Southern California
    Thank you.. I guess I should be clear on my intentions. My battery died and I'm in desperate need to have my car operational this weekend. I can't wait for shipping. I'm looking for something that autozone, Walmart or even Lowe's would carry that I could go pick up, like now. Even if it'll just be temporary. I can't afford the one at autozone at over $200.
  5. bisco
    52,393
    well, you can use any old battery, like a lawn tractor or motorcycle battery. as long as you can tie it down, it will only be a problem if you get rear ended and it explodes, or the battery emits toxic fumes inside the cabin from overcharging or something.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  7. bailor
    17
    Southern California
    Thank you! I live in the Temecula area and work in Orange county. There are Napa auto part stores, O'Reilly, autozone etc. I'll check those. Thanks again, I didn't want to spend money only to realize that I wasted money if it didn't work.
  8. padroo
    padroo Senior Member
    2,763
    2,252
    I heard Pep Boys sells a battery for Prius too, I believe it is an Exide brand.
    pdhenry and bailor like this.
  9. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    bailor likes this.
  10. Mendel Leisk
    41,907
    Check with Pep Boys. I know for third gen at least, they have a low priced, 100% compatible option, by Bosch.
    Addendum: see I'm about the 3rd or 4th responder with this hot tip...
  11. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    No they aren't.
    Pep Boys seems to have it covered with a Bosch.
    #11 sam spade 2, Sep 1, 2018
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    Short sighted.
    By the time you pay $50 for a temporary fix.....and then $150 for a permanent one......guess what that adds up to ??
  13. Cyvan
    Cyvan Junior Member
    27
    26
    Jamaica
  14. Mendel Leisk
    41,907
    Amazon has a feature called "garage" or "my garage": you can enter vehicle, check fit.
  15. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Amazon seems to think this is the correct battery, I have no reason to guess differently.
    www.amazon.com/dp/B000MS9VZK
    That is what i used, it wanted me to know if he had a XE hybrid or an XLE hybrid and I made up that part.
  16. wanderso
    wanderso Junior Member
    Portland
    I replaced the OEM battery with a Duracell battery from Batteries Plus.
    2006 Prius Base
