Got Check Hybrid System today
Discussion in 'Gen 3 Prius Main Forum' started by ChItalian1027, Sep 1, 2018.
  1. ChItalian1027
    ChItalian1027 Junior Member
    Carmel, IN
    Hi PriusChat, long time no post! So I recently moved to Carmel, IN and I was driving home from Lowe’s and one of the cells in the battery pack died and the car jerked because I was driving. Had no clue what had happened so I pulled over into a parking lot and used Google to see what happened. So I thought since I’m 5 minutes from home I can just use the gas motor to get me home and I will post this on PriusChat. Now I start work for T-Mobile a week from Labor Day, and this is my mom’s car and she retired this year so she won’t be driving much since my sister also lives in Carmel. My question is how much will it cost at the dealer to get a new pack? Or should I attempt to replace the whole thing myself?
    Thanks PriusChat!!
    49,371
    dealers average around 3k. some less, some more. if you feel up to it, see the install threads here and call around for pack availability and pricing.
    how many miles on her?
  3. bisco
    49,371
    how far are you from madison?
  4. ChItalian1027
    Carmel, IN
    bisco Madison Wisconsin? I think her car hit 76k miles
  5. bisco
    49,371
    yes. isn't it still under warranty?
  6. ChItalian1027
    Carmel, IN
    No, unfortunately it isn’t under manufacture warranty. Also when I was close to Madison when we lived in Chicago but my mom and I both moved to Carmel from Chicago. Carmel is 10 minutes north of Indianapolis.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    You could always check with Steve at Auto be yours in Seymour, IN. While it’s probably about 60 or so miles away, you could always call him to discuss your situation.
  8. Mendel Leisk
    38,644
    Have you had the car checked for codes? If not, it sounds like you're jumping to conclusions, after just a Google search.
    Could be inverter too, for one. But first things first, get the codes read. The simplest is a dealership service department, with Techstream diagnostics, and you get quotes while you're there, once it's determined what's happening.
  9. ChItalian1027
    Carmel, IN
    Raytheeagle- thanks for the info for Steve, I will give him a call on Tuesday.
    Mendel Leisk- I have a ScanGauge 2, can I use that to get the codes?
    Raytheeagle likes this.
  10. Mendel Leisk
    38,644
    It'll get some (I've used it thus), but I think a dealership diagnosis with Techstream is the way to go, with $1000's at at stake. They may do it gratis, or at most $100.
    Try the ScanGuage first, see what it shows.
  11. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    You had no clue what happen, but specifically how did you find out one of the pack died then?
  12. ChItalian1027
    Carmel, IN
    Mendel Leisk- Thank you I will see what codes I get with the ScanGauge
    grid- I did a Google search. I'm not new to cars but I am new to hybrids, thus why I created this thread to get information from you all.
  13. ChItalian1027
    Carmel, IN
    We took the car to the dealer on Tuesday to find out what happened. The inverter failed and they have to order it.
    bisco, Mendel Leisk and Raytheeagle like this.
  14. bisco
    49,371
    warranty?
    ALS likes this.
  15. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Bisco, isn't there a warranty extension out to 100K on the inverters?
  16. bisco
    49,371
    might be, or the ism module inside. it's all available at toyota.com/owners
  17. Quattro
    Quattro Member
    60
    28
    Silicon Valley, CA
    Toyota extended the warranty for IPM failures to 15years with no mileage limit. Search under Toyota warranty extension ZE3.
    • ZE3.pdf
      File size:
      542.5 KB
    Taxi/Limo and m.wynn like this.
  18. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    How about hand feed it here.
    m.wynn likes this.
  19. Quattro
    Quattro Member
    60
    28
    Silicon Valley, CA
    Found a pdf & added to my original reply.
  20. ledd4u
    ledd4u Junior Member
    28
    I got the check hybrid system message about two weeks ago. Took it to my dealer and they quoted me $3600 complete with tax. Car has 127k miles. First issue I have had. Since it was at the dealer they did three recal updates. I reset it by removing the negative terminal. The following few days i decided to remove the hybrid battery. This is what I found. Not good guys. So I removed all of the nuts and copper bridge plates and cleaned them all. I purchased the Dr Prius app and a Bluetooth device. Tested it and this is what it said. Then I did the load test. Got this. Just today it failed and gave me the message. Called dealer and new battery pack arrives tomorrow at 8:00 AM. $2319.95 plus 6% tax. Done.
    johnHRP, m.wynn, Mendel Leisk and 2 others like this.
