Help..the "alarm" I don't have went off
Discussion in 'Gen 2 Prius Main Forum' started by texvegas, Apr 16, 2006.
  1. texvegas
    texvegas Junior Member
    Englewood, FL
    My 2004 Prius does not have an alarm system. The other day while locked in my driveway the horn began to sound on and off just like an alarm that has been tripped. I do not have an alarm system on my Prius. It would not stop after unlocking the vehicle. It stopped only when I started it up. What is happening here?Thanks.
  2. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(texvegas @ Apr 16 2006, 04:35 PM) [snapback]240566[/snapback]</div>
    Panic mode triggered on your fob (red button)? I used to have that happen with my Audi but not yet with my Prius. The button would get pressed by other keys when I sat down in my family room next to the garage. No alarm necessary - I think we all have the panic button.
    - Tom
  3. texvegas
    Englewood, FL
    <div class='quotetop'>QUOTE(Tom_06 @ Apr 16 2006, 12:29 PM) [snapback]240583[/snapback]</div>
    Thanks Tom, I think this is probably what happened. Tex
  4. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Tex,
    Just to test, trip your PANIC and see if it's the same sound.
    ITBland likes this.
  5. texvegas
    Englewood, FL
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Apr 17 2006, 09:47 AM) [snapback]241003[/snapback]</div>
    I hit the panic button and nothing happened with car locked and unlocked. Someone else on another forum mentioned that it may be a failing 12v battery and I should have a load test done on it. Anyone else ever hear of this?
    <div class='quotetop'>QUOTE(texvegas @ May 3 2006, 10:46 AM) [snapback]249217[/snapback]</div>
    It worked.......you have to hold the panic button down for 2 or 3 seconds, then the horn starts to beep. This is not in the owner's manual...as far as I could tell, so it looks like this is what happened to me as far as my original post is concerned.Thanks.
  6. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    You need to HOLD the panic button for couple of seconds to get it to work.
    Edit... ok.. seems like u already figured it out...
  7. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    At some point there was this annoying pulsing car-horn-alarm going
    off outside, which I didn't think about too hard until I realized
    that it was closer than I thought, and then realized that I'd sat
    on the red button in my pocket. Then I was like "oh, *that's* what
    the horn in the prius sounds like??"
    Fumbling out the fob and hitting "unlock" shut it up.
    _H*
  8. dusty coates
    dusty coates New Member
    maryland
    I've been told by two dealers that my 2009 prius alarm goes off and it's something I'll have to live with. I have paid three tickets totaling 375.00 for the alarm goes off and the police have to respond to it. everytime it trips the fobs are laying on our table. listing on craigs list. going back to fords.
  9. bisco
    52,286
    Found On Road Dead? or, Fix Or Repair Daily?:p
    Raytheeagle likes this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    It is an acronym from my experiences(y).
