Motor (engine) starts in IG-ON mode?
Discussion in 'Gen 3 Prius Main Forum' started by CWM, Sep 7, 2018.
  1. CWM
    CWM Junior Member
    CA
    When I press the Power button twice - I do *not* touch the brake - the gasoline engine starts after approx 10 seconds - every time. The parking brake is still on, and I do not intend to go anywhere during this time. Is this normal?
  2. fuzzy1
    10,603
    If you do not touch the brake, then the gas engine should never start, and the dash display should not say 'READY'.
    Raytheeagle and Maarten28 like this.
  3. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    I would check if the brake pedal switch is faulty. Are your brake lights on all the time? Does your cruise control still work?
  4. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    Is it a cold start? If so, the engine has to reach operating temperature before going into electric mode. If the engine is warmed up, the ICE should not run after starting the car.
  5. Mendel Leisk
    41,901
    Yeah, foot off the brake, two pushes of the Start button, should put the car in what's traditionally known as "accessory" mode: all the interior lights, ventilation, radio on, but no engine start. I'd second @Maarten28 : sounds like a faulty brake switch.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    If the brake switch were faulty (always on) would it go into ready mode after just one push?
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Not a start at all. At least not supposed to be a start.
    The only thing that makes sense to me at all would be a stuck brake switch. But wouldn't that drain the 12v battery pretty quickly?
    fuzzy1 likes this.
  8. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    So according to thread title, it is normal for motor in car to start before car moves. Engine turns over first, then you put car in drive and car begins to move, that’s normal.
  9. jerrymildred
    11,517
    14,158
    Tampa, FL
    The title is very misleading. You need to read the original post itself. He didn't start the car. It is not normal for the car to start when doing what the OP did.
    "When I press the Power button twice - I do *not* touch the brake - the gasoline engine starts"
  10. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    If the brake switch was stuck on, I would think you would only need to press the button once for the car to turn on.
    When the cars in Ready mode are the brake lights always on?
    You could check by
    Firmly setting the parking/emergency brake. Maybe even chock the wheels.
    Walking around back and to see if the brake lights are on, even when you are not touching the brake.
  11. jerrymildred
    11,517
    14,158
    Tampa, FL
    I checked my car and the brake lights came on just by me opening the door (car off) and pressing the brake pedal. Lit up the whole garage. So, if it's a stuck switch, it should be pretty obvious.
  12. ChapmanF
    18,546
    Well, ehrm, "accessory" mode is where you get with foot off the brake and one push of the button. ACC will power small non-driving loads like the radio (and the power outlets, I think), but not the instrument cluster or the heat/ventilation.
    The mode traditionally called "on" is where you get with foot off brake and two pushes. Power to everything that's powered in ACC, plus the instrument cluster and warning lights and heater blower and pumps and turn signals and all that jazz.
    And of course "ready" is where you get pushing the button with foot on brake.
    If you're just trying to listen to the end of that captivating story on the radio, ACC will drain the battery a lot more slowly than ON.
    -Chap
    jerrymildred likes this.
  13. Mendel Leisk
    41,901
    I thought that's what I said. :confused:
  14. ChapmanF
    18,546
    One push is "accessory". Two pushes is "on". You called "on" "accessory". -Chap
  15. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    It’s a ‘10, the 12v is suspect, as is the traction, not suspect so much as aged.
    A wired problem, hm, 12v
  16. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    I was being a smarty pant, just want title of threads to be descriptively close to the issue on hand. If we, I mean I, want to do a search (no one does it anymore) I can find the post later to help someone out.
  17. jerrymildred
    11,517
    14,158
    Tampa, FL
    I should probably add windows to the list of things that work in "ON" but not "ACC."
    I had been thinking the same way about the title.
    I wonder if the world famous and greatly appreciated @Tideland Prius would be willing and able to edit the title to better introduce that actual question posed by the originator.
    #17 jerrymildred, Sep 8, 2018
  18. Tideland Prius
    16,618
    Done.
  19. jerrymildred
    11,517
    14,158
    Tampa, FL
    I appreciate that. Hope it helps people down the road.
