Small motor type thing making noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Assad, Sep 7, 2018.
  1. Assad
    Assad New Member
    Pakiatan
    Hi can any one please guide this encircled thing adjacent to ac filter is creating noise what is this pully type thing and what is the solution.
  2. Mendel Leisk
    41,822
    Not seeing anything encircled. Guessing this?
    Assad and AliPK like this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    That is some serious dust.......maybe the selector door actuator squeaking?
    jerrymildred, Mendel Leisk and AliPK like this.
  4. Assad
    Assad New Member
    Pakiatan
    Yes the motor operating this was out of order and replaced today problem fixed..
    jerrymildred, bisco and Mendel Leisk like this.
  5. bisco
    52,277
    congrats!(y)
    Assad likes this.
  6. Gypsy62
    Gypsy62 Junior Member
    North America
    I just bought a '12 plug-in that regularly, and seemingly randomly, cycles the sound of an "electrical servo" performing some function. The sound seems to be emanating from behind the glove box.
    After viewing your post, I'm wondering if that describes your (resolved) issue?
    Thanks!
  7. bisco
    52,277
    funny, we never got an answer as to what motor.
    you have the hvac fan below the cabin filter behind the glove box. could be some debris in it. turn it on and off, and change the speed and see if it changes.
    there is also a buzzing sound from the dash when you open the drivers door, and at times when you step on the brake. that's the brake accumulator, normal.
    Assad likes this.
  8. Gypsy62
    North America
    Thanks, Bisco: I was about to ask OP precisely what part they replaced, too!
    And I'll monitor whether the "servo noise" cycles with braking.
    Thanks!
  9. Assad
    Assad New Member
    Pakiatan
    Actually motor controlling AC air flow was making noise.
  10. bisco
    52,277
    thanks! so that is the fan under the filter.
  11. Assad
    Assad New Member
    Pakiatan
    It was motor controlling ac air direction which was making unusual noise
  12. bisco
    52,277
    ah, sound like a ventilation door motor
    Assad likes this.
  13. Joemcb
    Joemcb Junior Member
    Michigan
    Three Touring
    I think this is it. Mine is a little squeaky at times
