B drive? How does it work?
Discussion in 'Gen 2 Prius Main Forum' started by ivfarmboy, Aug 9, 2006.
  1. ivfarmboy
    ivfarmboy New Member
    107
    Can someone explain what the B drive is for on the shifter. I read the manual but I guess I am just not that intelligent. I still don't know why I would use it or what it is used for? Is it like a "Jake" brake on older trucks? Thanks and sorry for the stupid question.
  2. dipper
    dipper Senior Member
    1,242
    252
    Image you driving a manual tranny car. Now when you go downhill, you might downshift from 5th to 4th to slow the car down without having your brakes overheat... also known as engine braking (that is the purpose of the "B" mode).
    In the Prius, the "B" mode does the same thing (sort of). If I am correct, the "B" mode would not recharge the battery though.
  3. cagemo
    cagemo Member
    132
    california
    you b needing to read this
  4. tazman
    tazman Junior Member
    58
    Kailua, HI
    "B" will recharge the battery and slow the car down. Like putting an automatic in 2nd. Don't drive with it on all the time though according to the manual use it only down hills then switch back to "D". I only use it for steep grades as I like to have the car roll with minimum resistance.
  5. richard schumacher
    7,664
    1,046
    United States
    Yes, it's like a jake brake: it tells the computer to use the engine as a big air compressor when necessary to assist braking action. On average it makes less use of regeneration (energy recovery into the battery) so it reduces fuel economy, and so, like a jake brake, it should only be used to avoid riding the brake when going down a long hill. If you want to play with it in other situations it won't damage anything (except probably your fuel economy).
    Clarifications:
    - "B" stands for "Brake", not "Battery". The car always uses the battery for energy recovery whenever it can. You do not have to shift to "B" to do ths, indeed you should not use "B" for normal driving because it will do less energy recovery (on average, under most ordinary conditions) than "D".
    - Unlike downshifting in a conventional transmission "B" does not change the gear ratio between engine and wheels. You will not get more wheel torque in "B". Still, it has been suggested that "B" may be useful when driving very slowly on very slippery conditions, because it may help prevent the average driver from hitting the brake pedal too hard.
  6. ivfarmboy
    107
    <div class='quotetop'>QUOTE(cagemo @ Aug 9 2006, 12:17 AM) [snapback]300088[/snapback]</div>
    Thanks, wow that explains a lot. One question - What is autocrossing?
    Thanks, I think I understand it now. Don't really have many long steep mountain roads around here but it is nice to know it is there if I need it...
  7. tazman
    58
    Kailua, HI
    Autocrossing, it's a form of autoracing, but you run against a clock not other cars, at least not car to car. A course is set up in any big parking lot or other such big area with cones. From a dead stop you "race" thru the cones. Penalties happen when you hit a cone and are counted in seconds off your total time. Any car can run autocross, so there are lots of different classes. Most of the time only a helmet, setabelts and decent tires are needed to compete. There may be a short drivers meeting to let you know the rules as well as a rule book. Most meets are run by SCCA rules.
  8. Rancid13
    Rancid13 Cool Chick with a Black Prius
    2,452
    Los Alamitos, Orange County, CA
    It's for simulated engine braking, similar to going into 2nd in an automatic like someone in a post above mine mentioned. I've only used it when coming down a long and/or steep grade/hill, to avoid keeping a foot on the brake for an extended period of time while trying to keep my speed in check. Good for very hilly and mountainy areas. Being a snowboarder, I spend a lot of wintertime in mountain areas and have found B mode to be helpful in mountain driving.
  9. roadrunner
    roadrunner His (blue) and hers (black).
    61
    36
    Perkasie, Pennsylvania
    2015 Prius c
    Thanks for the info on the B mode. Next time I drive up Mt Washington, NH I will use it on the way down the 7.6 mile road. That should keep the brakes from overheating. I have never used the B, but will now that I know the purpose.
