Just when you thought Entune 3.0 couldn't get any worse
Discussion in 'Toyota Hybrids and EVs' started by azjerry, Sep 13, 2018.
  1. azjerry
    azjerry Junior Member
    29
    Phoenix
    Got an email from Toyota today stating that Entune 3.0 will receive an update in November that will remove Pandora as one of it's apps. It's not like there are very many apps to start with and now they remove the one I do use. I've already removed Scout as it can't be depended on.
    I just wish Toyota would add convert to Android Auto and Apple Carplay. Sigh.
    52,386
    i gave up eons ago
  3. laskier
    laskier Junior Member
    Salt Lake City
    Boo, shame on you Toyota. Pandora was about the only app I ever used on Entune. I heart radio has been bankrupt for years, why not get rid of them instead!
    iPad ?
  4. Mendel Leisk
    41,898
    Ignorance is bliss. Our dash:
  5. CamryDriver
    CamryDriver Active Member
    541
    391
    Arkansas
    This is the biggest stain on an otherwise awesome vehicle.
    BTW I just updated the maps on Mom's Mazda. It was easy. I like the way Mazda does Nav. Free updates for 3 years. The system still works after 3 year but your maps get old. I can live with that.
    I despise the way Entune and Scout work on my Camry. Just got air vent dash mounts for our phones. That should do the trick...
    No way Toyota will ever see a cent of my money for any of their services. Honestly even if their apps were good it is unlikely I'd give them any money but the way it stands there is zero chance.
    It is weird how much I like my car but at the same time how much this infotainment business hacks me off. If I don't buy a Toyota next time this will be the reason.
  6. Mendel Leisk
    41,898
    Something else they do better: our son got a CX-5, and I see tpms sensors are only $35 apiece (online Canadian dealership, free shipping), and the car will recognize new sensors, no dealership intervention needed, simply by driving around for a few minutes.
    Toyota should wake up on this: you can have a generally great product, but if there is some element that is maddening, and/or you're gouging customers after-sale, they're gonna get alienated.
    CamryDriver likes this.
  7. followingalex
    followingalex Junior Member
    42
    New York
    here's the email:
  8. bisco
    52,386
    never used entire in 6 years, won't miss it.
    not the way it should be, but it is what it is
  9. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    I still don't know what Entune does. This whole infotainment things are something I don't look for in a car. I already have enough information to absorb and quite easily entertained without all those gadgets.
    Guess what, Honda Clarity is even better on that end. They removed TPMS sensor all together, and went with indirect TPMS. There is no radio signal emitting sensors to replace inside of tires. All the better.
  10. azjerry
    29
    Phoenix
    Yours is slightly different than mine. Open Table and Facebook Places were never an option for me, not that I would have used either.
  11. Trollbait
    12,680
  12. Salamander_King
    11,024
    8,970
    New England
  13. TLfromVA
    TLfromVA Junior Member
    Virginia
    Let me give Toyota a little credit here: At least their recent announcement got me off my haunches to explore the possibility of replacing my 2014 Prius 4's OEM head unit....
  14. azjerry
    29
    Phoenix
    Just for grins I looked at Crutchfield to see what might be available for 18 Camry (Hybrid wasn't even listed as a possibility) and they didn't have anything. Since a number of other car settings are done through the head unit I'm not surprised.
    Found another problem this past week.
    - I drove the Camry last and Entune was connected to my phone. My phone is set as the primary phone.
    - I was standing outside the car when my wife got in and started the car. Entune connected to my phone. Understandable enough, I guess.
    - She drove away and Entune never realized that my phone wasn't there anymore and, therefore, didn't connect to her phone as I would expect.
  15. bisco
    52,386
    how does indirect tpms work?
    are you driving a hycam? what year?
    #15 bisco, Sep 29, 2018
  16. Salamander_King
    11,024
    8,970
    New England
    As I understand it, indirect TPMS works by ABS sensors. When one tire lose air, slight differences in rotational speed can be detected. With this system absolute tire pressure can not be known. Also in very rare event when all four tires lose air at the same rate, system will fail to detect the loss of air. It was used in many older cars for simpler implementation, but in time taken over by direct TPMS with radio signal emitting internal sensors. I read in an article that with more sensitive ABS sensors today, indirect TPMS is coming back in some European and Japanese cars.
  17. bisco
    52,386
    sounds good. you can't tell what the pressure is in the prius tires or what tire is low, so how much worse can it be.
    Salamander_King likes this.
  18. Trollbait
    12,680
    Since it looks at wheel rotations, the wheels have to be spinning for it to take a measurement.
    If the car isn't telling you actual pressures with the radio sensors, I'd be fine with its faults.
  19. Salamander_King
    11,024
    8,970
    New England
    Agreed. Plus, if dealing with direct TPMS for tire changes (twice a year) is not as complicated and expensive, I would prefer direct method. In theory, direct TPMS is better for knowing actual tire pressure real time even when car is sitting at parking. However, my experience with a car equipped with direct TPMS is that it always had some lug time before warning light came on. All of the cases were slow leak.
  20. Trollbait
    12,680
    If you are pumping your tires higher, keep in mind the TPMS warning is set against the manufacturer pressures. Some can be reset to the users level.
    The Camry SE actually displays the tire pressure readings. It reads a little higher than my hand gauge, but is nice, since I don't need to swap in winter tires.
