Looking for Cell Phone Holder
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Zardoz, Aug 30, 2018.
  1. Zardoz
    Zardoz Member
    86
    52
    Show Low, AZ
    I am looking for a cell phone holder that will straddle the hazard flasher push button and grip on its sides instead of the ac vent vanes. The last one I had attached to a vane broke one! Ouch!
    atterbury90 and Smaug1 like this.
  2. cachevan
    cachevan Junior Member
    Barstow
    I've been using the iOttie Easy One Touch 4 CD Slot Car Mount Holder Cradle . It inserts into the CD player slot. So far, it has been working great.
    TGrracie, atterbury90 and Mambo Dave like this.
  3. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    I'll be watching this thread. I bet there's an elegant solution somewhere that doesn't involve a suction cup mount, CD slot mount or vent mount. Maybe a sandbag mount or double-stick tape mount?
    I have a rubber spider type one that attaches to the vent vanes. I had it on my Accord, and it worked fine and was soft enough that it didn't break any vanes over 7 years of ownership, including cold winters and hot summers. It bounces around a bit, and the phone gets hot when the heat's on, and cold when the A/C is on.
    I don't like the CD slot ones, because I still listen to CDs. Love them. Many folks don't remember how clear they sound until switching back after years of listening to MP3s or worse, streaming music.
    It's a slow day at work, I'm going to browse a bit for one...
  4. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    After reading a bunch of reviews and considering all the factors, I wound up ordering this one for $12:
    I put it in this morning and I really like it. They make one with a much longer arm, which gets it up much closer to eye level, but the longer arm also amplifies the effects of road bumps, such that it will often be shaking while driving down the road.
    This one doesn't move at all, and it's a great fit. I'll try to remember to add a pic later.
    TGrracie likes this.
  5. RoadNoise
    RoadNoise Active Member
    136
    187
    Huntsville, AL
    Two Eco
    I don't see it :barefoot:?
  6. krmcg
    2,592
    2,393
    Whittier, CA
    I see it...
  7. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    Go to Amazon and paste this into the search field: (without the quotes) "
    Macally Adjustable Automobile Cup Holder Phone Mount for iPhone X 8 8+ 7 7 Plus 6s Plus 6s SE Samsung Galaxy S9 S9+ S8 S7 Edge S6 S5 Note 5, iPod, Smartphones, MP3, GPS etc (MCUPMP)
  8. RoadNoise
    136
    187
    Huntsville, AL
    Two Eco
    Thanks, I found it. And I like it, but I like my cup holder even more (need both when traveling with my wife). Considering ordering the CD slot mounted version. Decisions, decisions...
  9. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    You've got two cupholders, can you share a drink? :D
  10. mudworm
    mudworm Member
    84
    99
    SF Bay Area
    2018 Prius
    What I have is not what the OP was asking for, but I like my phone holder very much, so figured I should share in case others are interested.
    Pros:
    1. No installation required
    2. Does not block any vent, display, or view
    3. Portable -- can be moved around (e.g. driver's side or passenger's side)
    4. Cheap
    5. Sturdy (My daily commute is on windy mountain roads with tight turns and the phone never flew off side ways)
    I like it so much that I bought a second one for home use as sometimes, I like to have my phone perched up.
    Cons:
    1. It's not locked in. When car has a sudden jump (e.g. when hitting a speed bump at speed), the vertical jolt might jettison the phone out of the holder. In the two months I had this thing, it happened to me about 3 times in the beginning stage when I either didn't see the bump or forgot that this could happen. Now if I see a big bump or dip coming, I reach out and steady the phone for a 1 second and it has not fallen out again.
    2. If you live in a flatland, you probably don't need this. I go up and down hills alot, so it works better for me when I made a minor mod to it -- I cut off the backside of the holder and put the trimming under the front side just to prop up the front a little, so the phone's center of gravity moves back a tiny little bit, which works better when I climb a steep hill.
    I like it so much that I bought one for home.
    I like my view of the phone like this so I can see it without moving my eyes off the road.
    No installation is required. It just sits there. This also shows my minor modification.
    I put my old phone in the holder.
    TGrracie, jlimgarfield and Smaug1 like this.
  11. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    Very cool. Can you provide a link or at least the make and model of it please?
  12. mudworm
    mudworm Member
    84
    99
    SF Bay Area
    2018 Prius
  13. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    Purplesquirrel44 and krmcg like this.
  14. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    Finally, I remembered to shoot a couple pix of the cupholder mount I've got and referenced above.
    One is the "driver's eye view", the other is a lower angle. 20180921_092108_HDR.jpeg 20180921_092118_HDR.jpeg
  15. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    Just looking for any new, tested and trusted options/ideas for Gen4's. As so many Priuses are being used by Uber and Taxi drivers, I bet there are some solid recommendations.
    In my case, the holder must be able to take a charging cable - the wattage of Qi wireless charging for iphones can't keep up with the energy demands of the apps. I like the CD-holder option for a start, but don't want the holder or cell-phone blocking the radio screen.
    Can't be magnetic as I do use wireless charging at home. For the short-term, low-cost option, I ordered this Universal Cell Phone Car Holder CD Slot Mount - Smartphone, iPhone, Samsung, GPS | eBay
    (I can't imagine a worse option than a cup-holder mount; we already have enough clueless drivers taking their eyes too far off of the road to use a low-mounted cell-phone holder for anything.)
    #15 Mambo Dave, Nov 6, 2019
  16. Itmaybejj
    Itmaybejj New Member
    2019 Prius
    I've been really happy with the ProClip one that mounts around the vent. I ended up spinning my phone horizontal so it doesn't block the upper dash or multimedia screen. And then I canted it ever so slightly upwards, so that its backplate diverts the vent down towards my lap, which is where I usually aim it anyway.
    Cupholder mounts are too low for me; I want my nav higher in my peripheral vision. And yeah I have a vane-pinch mount in my other car, and I'm always worried I'll crack the vane or the pressure clip will let go of my phone when I got a bump.
  17. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    So mine is absolutely satisfying me ( Universal Cell Phone Car Holder CD Slot Mount - Smartphone, iPhone, Samsung, GPS | eBay ).
    With the mount coming out of the CD slot, and going up, the radio screen is not blocked at all save for one small area at the top by the twist-screw that expands the cd-slot grip.
    The cell phone is close to perfect (perfect being about eye-level, but within the direct forward view of the driver) for navigation via phone. I'm done shopping for a mount unless this one breaks. It may not be the super-high-tech phone gripping mechanism of some holders, and the holder-release is archaic, but it's working.
  18. blane
    blane Carmudgeon
    98
    56
    NJ Suburb of NYC
    2019 Prius
    I used an Mpow CD-Slot mounted cell phone holder for years in my 2011 Prius. I transferred it to my 2019 Prius XLE and it works perfectly.
    Mine is an older model, but it's similar to this one http://tinyurl.com/t9zpj6c
    Since I have hardly ever played a CD in any of my cars, the CD slot is a great stable location for me. I use it to hold my phone while navigating, so the landscape mode is perfect and doesn't obstruct the instruments or radio display.
    Mambo Dave likes this.
  19. Dngrsone
    Dngrsone Underwhelmed, to say the least
    189
    Lost in a desert somewhere...
    I had a suction cup Qi charger in my previous car, but the windshield is so far away in the '16 model 2 that it's unworkable.
    ...unless I attach it to the little triangle window in the door. But then cabling would even more of a nightmare.
    All the weird curves in the dash makes finding a place for a fixed mount with decent field of view just as difficult.
    I like Mudworm's stand, though; I might try to find one like that.
  20. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    Try a CD-player stand. It's handy, close to the driver, and just about the right level.
