Forced Warp-Stealth Mod?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by darkecho, Aug 11, 2006.
  1. darkecho
    darkecho New Member
    60
    Ok, after reading about Warp-Stealth, It sounds like it is a significant mpg increaser. but It also sounds like it is difficult (causing frustration and even increase risk of injury) to keep the pedal in the proper threshold.
    So here is my proposal. Because I have read that the goal is to supply the engine with ~10kw or someamount of power, why not rig up a switch or set up a mechanical device that assists with the location of this threshold for warp-stealth.
    an electrical solution would be a button that sends the correct signal down the pedals wire so that you hold that button and it Simulates the perfect pedal position, catch my drift??Glide, whatever..
    OR make some sort of stopper that you can put in place that will disallow you to move the throttle pedal past that perfect spot. something that just applied some resistance so that you know when to stop pushing, but if you wanted to go faster, just push harder and have the object give.
    any ideas? This sounds like it would work well and has the potential to greatly help those of us with a lack of pedomuscular control :D
  2. Cheap!
    Cheap! New Member
    1,157
    I've put some thought into this and at first I bought a remote throttle adjuster. It is a cable that runs through a housing like bicycle brakes, but with a large button on one end. I could not bear drilling a hole in my dash so I thought about it some more.
    Next I realized that the whole car is fly by wire and you could use a small adjustable potentiometer to bypass the peddle and just send a slight signal to the computers. I would then want to add a push button to turn it on and off. Finally, I would want to one day add a safety feature that if you pressed the brake it would shut off automatically.
    I realized that you still use power from the battery to run the motor during this process. That is why I want to build a Trans-Warp Stealth Drive to power the system during Warp Stealth and allow for more use of the Warp Stealth without running down the battery so the engine has to come back on.
    Finally, I figured I could use a switch to separate the main battery from the motor all together. With another switch to separate the accelerator pedal from the system all together. Then add an additional battery pack. You could keep all the systems running from the main battery with the car in neutral. Let the additional battery pack power the motor through the accelerator pedal. It would be two independent systems working at the same time.
    The first system would be the Prius without the motor or accelerator pedal. The Prius would just think your not pressing the pedal. When you coast the Prius would be in neutral so there would be no regenerative brakes working.
    The second system would just have three parts, A battery, accelerator, and the motor.
    With a flick of a switch you could be back to the second battery just sitting in the trunk and the Prius working normally again. You would not need spoofing circuits like cal-cars uses.
    The limitation of the second system would be a 34 mph speed limit. The distance would depend on the size of your second battery pack.
    I hope to be able to do this sometime this year, or early next year. That way I could drive 30 miles a day on battery power charged from a solar array on my home during the week. On weekends I would have to use gas for long trips. During long trips I might just remove the battery to save space and weight, then pop it back in for the workweek.
  3. kDB
    kDB New Member
    241
    Fenton, MO
    one thing to think about first.
    at first it would seem there are three levels of >40mph ev: green (regen) yellow (warp stealth) and null (no energy paths, true warp stealth). but in reality there's a lot more. you don't have to hit that magic spot to cause a difference. sure if you have a real steady foot you can achieve true warp stealth, but even without one you can come close.
    when it's green the car is in regen mode, but it varies depending on how far the pedal is pressed while it's green. in "true warp stealth mode" what is actually happening is the car is regenning the same amount of power needed to spin the ice. it might be more beneficial to get a slightly higher regen, just barely less pressure on the pedal.
    conclusion:
    don't worry so much about hitting that magic point, just give it enough pressure to remove most of the regen.
    this is only my opinion.
  4. darkecho
    darkecho New Member
    60
    so true warp stealth is no energy arrows?
    I thought you were supposed to get the battery to output enough energy to spin the motor so that it does not cause drag... so is that no arrows but in actuallity, there IS energy coming from the battery?
    is the pedal position for stealth mode below 40 the same as the position for the stealth mode above? If so, you could have asingle switch that sends the correct current down the pedal wire to the ECU for stealth and warp stealth
  5. Cheap!
    Cheap! New Member
    1,157
    From my observations it position of the pedal needed to activate warp stealth varies depending on the SOC of the main battery. The more energy in the main battery the easier it is to achieve Warp Stealth. As the SOC drops toward four bars it is much harder to get in to Warp Stealth, if at all.
    So, the pedal position changes every time you try to Warp Stealth.
    Has anyone else noticed this?
  6. darkecho
    darkecho New Member
    60
    I agree with you, but I wonder if there is a certain pedal position that is at the beginning of the threshold no matter the SOC... for example
    at max SOC the pedal threshold for warp stealth may be 15%-25% pedal depression,
    at half SOC, the pedal threshold may drop from 25% to 20%, making the range 15%-20%
    and so on, until the SOC reaches a level where 15% pedal depression does not activate warp,
    anyways, what I am saying is, if you could somehow simulate 15% pedal depression with a button, then no matter the SOC, you can get into warp, as long as warp is possible.
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(darkecho @ Aug 12 2006, 09:57 AM) [snapback]301834[/snapback]</div>
    I've never seen any mpg increment or any real mpg increment report about the Warp-Stealth.
    Would you please let us know the pointer?
    Ken@Japan
  8. darkecho
    darkecho New Member
    60
    <div class='quotetop'>QUOTE(ken1784 @ Aug 13 2006, 09:25 PM) [snapback]302790[/snapback]</div>
    http://techno-fandom.org/~hobbit/cars/warpstealth.html
    I dont know, It seems like an accepted technique for improved MPG... Nothing concrete to touch my eyes, but why is there so much hype about it if it doesnt help?
  9. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(darkecho @ Aug 14 2006, 02:37 PM) [snapback]302878[/snapback]</div>
    Again, I can't find any improved MPG number on his site.
    Ken@Japan
  10. darkecho
    darkecho New Member
    60
    <div class='quotetop'>QUOTE(ken1784 @ Aug 14 2006, 01:44 AM) [snapback]302902[/snapback]</div>
    Hmm, well... I dont see one either but, why would he go through the trouble if it provides no increase? what have you found to be the most efficitne, MPG increasing method of driving at speeds above pulse and glide ability?
  11. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(darkecho @ Aug 15 2006, 02:49 AM) [snapback]303077[/snapback]</div>
    I don't know.
    Let's think about this way...
    There is about 510N(newton) running resistance at 100km/h(62MPH). Prius requires 51MJ of energy to run 100km.
    It consumes 3.98L of gasoline when the system efficiency is 37% max, which means 25.1km/L(59MPG).
    So, the max ideal mileage number is 59MPG at 62MPH. There is no magic or no(or very little) space to improve mpg number above 42MPH.
    Below 42MPH, we know the P&G works well. A newbie or just drive type see about 50MPG, the P&G masters see 60-70MPG and the marathon team saw 110MPG. There are huge improvement.
    I would suggest to use CC and just relax above 42MPH.
    Ken@Japan
  12. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(ken1784 @ Aug 14 2006, 10:38 PM) [snapback]303316[/snapback]</div>
    Apparently there is space to improve it. See this:
    http://techno-fandom.org/~hobbit/cars/sweet/
    (Found through a related discussion in Yahoo's Prius Technical Stuff group)
    Admittedly he has installed instrumentation that most Prii don't have. But still, he demonstrates the capability of MPG in the upper 60s at highway speeds. He also has some guidance for those of us without his instrumentation on how to use the MFD and some degree of guesswork to approximate what his instruments tell him quantitatively.
    Jim
  13. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(JimboK @ Aug 15 2006, 08:40 PM) [snapback]303429[/snapback]</div>
    I'm looking forward to seeing the real improved numbers than the CC method.
    Has anyone seen such improved numbers than the CC method?
    Ken@Japan
  14. darkecho
    darkecho New Member
    60
    So, assuming that CC is the best method above 41mph..
    is it still possible to tap into the throttle wire and send simulated signals to the ECU to maintain glide/stealth/deadband modes?
  15. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(darkecho @ Aug 16 2006, 07:22 AM) [snapback]303768[/snapback]</div>
    I gave up because of fail-safe issue, but Bob Wilson is trying...
    http://autos.groups.yahoo.com/group/Prius_...f/message/17844
    Ken@Japan
  16. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I'm really just starting to explore this sweet-spot thing and a lot
    more research needs to be done, so I don't *have* any hard numbers
    other than the MFD shots given, how I do on the next few months'
    worth of tanks, and a fairly positive feeling that I'm onto something
    fairly useful here. Hard-line A/B/A/B testing of sweet-spot
    methodology vs. cruise control would take a while, over a few
    different round-trip routes involving varied sets of speed and
    terrain, and I haven't had enough time to go out and do that.
    One or two other people have tried messing with the non-instrumented
    guidelines and seem to have come up with good results, but that's
    not hard numbers either.
    It *is* clear to me, nonetheless, that warp-stealth *is* the moral
    equivalent of "glide" at high speed. It pulls a little more battery
    current, but about the same as the "slightly-augmented-glide" I've
    come to favor over pure no-arrows mode [it helps keep my speed more
    uniform, somewhat for the benefit of people behind me]
    _H*
  17. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    All we know is there is no magic above 42 mph. Just slower speed results better mileage.
    Regarding to the throttle control, our throttle is just for a power request signal.
    Below is very good study about this, especially page 49 - 62...
    http://www.engin.umd.umich.edu/vi/w4_works.../Miller_W04.pdf
    Ken@Japan
  18. KS_prius
    KS_prius New Member
    34
