Weird transmission
Discussion in 'Gen 2 Prius Main Forum' started by golfmk681, Sep 23, 2018.
  1. golfmk681
    golfmk681 Active Member
    264
    105
    los angeles, ca
    So I noticed this happening in the last 1 month. I google this youtube video and my car does sound like this. It only happens at low speeds or at idle. It doesn't happen when I am stepping on the gas accelerating.
    It began happening (or I noticed it) when I was going to the store during lunch. I was idling after buying something and starting the car. Kinda sounds rough; check out the youtube video. I notice it when I am traveling atleast under 45 mph, never at freeway speeds. Any clue? I happens a few times when I am driving but again a lower speed threshold. Usually it goes away, then comes back for a few minutes, then goes away again.
    There's no check engine lights and I have no check engine lights since my battery was replaced.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Not good.
    Sounds to me like timingchain slop. I never heard that sound before on this engine.
    Take a long screwdriver and hold it up to your ear and put the other end on areas of interest. Hold it to the valve cover the timing chain is attached on the left side of the valve cover. That’s the front of the motor. You can isolate sounds with the screwdriver.
    Listen through it.
    Have you ever run the engine so low on oil it threw check engine lights?
    How has the oil maintenance been managed?
    jerrymildred and Raytheeagle like this.
  3. golfmk681
    264
    105
    los angeles, ca
    Ummm well I'm not the longest owner so I have no idea if it has ever run low on oil.
    Raytheeagle likes this.
  4. audiodave
    audiodave Active Member
    800
    272
    US
  5. golfmk681
    264
    105
    los angeles, ca
  6. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Wouldn’t @JC91006 be able to help with this answer:whistle:?
  7. kens97uber171
    kens97uber171 Active Member
    177
    133
    US
    One thing can be an issue is ignition coils..
    They can make weird noises.. the engine can be misfiring makes a weird knocking sound.. often goes away at higher RPM..
    Or as someone else mentioned could be timing chain tensioner. Can use a stethoscope or a long screw driver put it to your ear and put the point to the part you suspect and listen to the engine.
    audiodave likes this.
  8. golfmk681
    264
    105
    los angeles, ca
    eh I don’t expect extended support post private sale lol. It would be like me selling my VW and getting a call from the buyer a month later I’m like I ain’t carmax.
    Ok timing chain and ignition are good leads. I thought it was the transmission so I did a fluid change. There was plenty of fluid before I drained it and it was still pink so it was recently serviced.
    I must say... This is a lesson learned for me buying a high mileage car. I'm at a point where I can't spend that much time on my car. Too many responsibilities. I've dropped like 2k on this I don't really wanna drop another 1k in repairs. It sucks caue I just bought new tires and a lightly used battery :(
    #8 golfmk681, Sep 23, 2018
  9. golfmk681
    264
    105
    los angeles, ca
  10. PriusCamper
    PriusCamper Senior Member
    12,814
    5,196
    Pacific Northwest, USA
    It's really hard to accurately hear a sound over the internet, but If I were in your situation I'd look for vacuum leak for an easy solve, failing that a full clean & inspect of all things intake to ICE also Toyota techstream software is well suited to this one....
  11. kens97uber171
    177
    133
    US
    Ignition coils are available at Rock Auto for $20 each. Easy to change. Get new plugs while your at it.. don't go cheap on the plugs. NGK, or Denso.
  12. golfmk681
    264
    105
    los angeles, ca
    Ya I’ve tried recording video but it doesn’t pull the sound accurately.
    Ok I’ll try the tech stream first.
  13. golfmk681
    264
    105
    los angeles, ca
    I changed the spark plugs. You would think the ignition issue would persist at high speeds though right?
  14. kens97uber171
    177
    133
    US
    Not necessarily, often ignition issues seem to smooth out above a certain rpm.
    Coil pack issues are a known problem as they age..
    If you had a real trans issue I think you would hear it at all different speeds.
    Worth a shot... If you know someone with a Prius that runs well worth no issues you could swap there could.. noise goes away.. you have a confirmation on the diagnosis.
  15. valde3
    valde3 Senior Member
    2,002
    749
    Finland
    Listen where the noise comes from with screwdriver or stethoscope. If noise comes from the engine you probably should just replace the engine.
    If the noise comes from transmission or flywheel it probably just engine running unevenly. Then you can try to identify the problem with scanner. Fuel trims should tell you if it’s vacuum leak or fuel pressure. Misfire monitors should tell you if it’s a single cylinder. Then you can find out if it’s plug, coil, injector, or something else.
  16. JC91006
    JC91006 Senior Member
    16,774
    8,570
    Wow you put a lot of miles on this car in such a short time.
    When you purchased this car, you asked about the transaxle fluid and I told you everything was New in there, including the seals. So the fluid change you did was a bit early with less than 20k on the fluid.
    The car has never run low on oil, the previous priuschat owner was very meticulous in the maintenance of that car. It didn't burn much oil either.
    I think you should look at the coil pack and plugs again. Cheapest route to take.
    As for the $2000 you've spent on battery and tires, that can easily be resold for 3/4 of your money back if you need to sell it
  17. Mendel Leisk
    41,548
    No warning lights would mean no stored codes?
  18. JC91006
    16,774
    8,570
    I remembered you recently did the plugs and valve cover gasket. I think you should revisit that repair work and make sure the plugs are seated properly and not loose.
