The car. It just stopped.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by RedRedRed, Sep 25, 2018.
  1. RedRedRed
    RedRedRed Junior Member
    25
    Los Angeles, CA, USA
    Was in the highway. A red triangle with an exclamation point light came on on the dash, so did a little red car with a exclamation point on the Touchscreen display, the check engine light, the word “problem”, there was a lot. End result the car shut off and would not turn back on. When I press the break and power button I get power to the car but the “ready” light does not come on and the engine doesn’t kick in.
    Any guesses on what happened?
    DLC82SV likes this.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Soooo many possibilities, but if you turn it off, wait several more minutes, then try it again. If it goes ready after cooling for a while, it was probably an inverter overheat problem. That would fall in line with an inverter cooling pump failure. Have you been having any problems with your air conditioner recently? It's usually one of the first things to start acting funny when inverter temp goes high.
    DLC82SV and Dxta like this.
  3. RedRedRed
    25
    I waited with it almost an hour. Wouldn’t start.
    No issues with the AC lately.
    DLC82SV likes this.
  4. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    1) A multitued of possibilites could case the issue. So get the codes read.
    2) Based on your description, it sounds like a failed inverter pump. When the Inverter begins to overheat, you get idiot/warning lights. Failure to pull over immediately and troubleshoot the problem or get a tow, can lead to more expensive repairs. The inverter may possibly be toast now.
    3)
    Several HOURS, not minutes, will definetly allow the Inverter loop to cool down, to possibly being driveable again.
    65C-111C (149F-232F) seems to be the range for the Inverter coolant temp; What IS the maximum acceptable inverter temp?? | PriusChat
    4)
    ONE HOUR is insufficient for Inverter coolant temp to cool down.
    When the Inverter begins to overheat, unnecessary electrical demands are cut off (ie Air Conditioning), to lower the electrical demands/heat build-up on the Inverter. As the Inverter temp continues to rise and approach critical/danger levels, the car will begin to shut things down and ultimately shut itself off, to protect itself from you.
    In the future, when you see warning messages, PULL OVER!!!! Something major or minor may be amiss.
    5) Check for fluid movement in the Inverter coolant overflow bottle.
    5a) Car OFF, open engine hood, open Inverter coolant overflow bottle. Notice the calm/stillness of the coolant.
    5b) Make car IG-ON or READY. Do you see fluid movement (a calm flowing gentle stream)? If the area is quiet enough, you will hear the inverter pump (sounds like an aquarium air pump).
    5C) If you do not see fluid movement/hear the Inverter pump, you have a failed Inverter pump. Replace, and all should be well, unless the Inverter is fried.
    DLC82SV likes this.
  5. RedRedRed
    25
    Got a guy coming this AM. He thinks it is the inverter. I’ll keep you posted.
    DLC82SV likes this.
  6. Mendel Leisk
    41,791
    Yeah sudden precipitous failure, often it's the inverter.
    DLC82SV likes this.
  7. RedRedRed
    25
    I just got to the car after leaving it overnight and it still won’t start. So I’m guessing it’s not the inverter?
  8. Mendel Leisk
    41,791
    No, I wouldn't guess that.
    DLC82SV likes this.
  9. RedRedRed
    25
    Isn’t it supposed to start after cooling?
    DLC82SV likes this.
  10. Mendel Leisk
    41,791
    No clue really, but I've heard when inverters die they stay dead.
    DLC82SV likes this.
  11. DLC82SV
    DLC82SV Member
    241
    119
    It will have logged the codes if your dash lit up like that. The DTC's hold the key. There are many ways to read the codes. Just make sure it is a hybrid compatible code reader. Not just a cheap obd2 scan tool.
  12. exstudent
    2,214
    905
    Torrance, CA
    YES, if the Inverter is not fried.
    But, I will assume you continued to drive despite the vehicle SCREAMING at you for help (lots of warning lights), resulting in the vehicle shutting down.
    Did your 'guy' retrieve the codes?
    #12 exstudent, Sep 26, 2018
    DLC82SV likes this.
  13. DLC82SV
    DLC82SV Member
    241
    119
    One guy or gal on here put tape over all the lights because "the car was running fine". I'm like WOW!
    That person's next post will probably be. Prius just dies out of nowhere.
  14. George W
    George W Senior Member
    911
    514
    San Antonio
    Your statement reminds me of a couple Sellers when I was in the market. There would be warnings on the dash, and they'd say something like, "I've been driving with this for a year, and nothing's happened yet".
    DLC82SV likes this.
  15. DLC82SV
    DLC82SV Member
    241
    119
    Right! I just snooker when I hear that. I can't believe people will continue to drive knowing a car is basically crying out for help. Then act surprised when it finally give out on them. Like, the darnedest thing happened today. After only 2 years of my car roaring like a lion, my wheel just fell off. SMH!
