Roof Rack degrade
Discussion in 'Gen 3 Prius Fuel Economy' started by spiderman, Sep 28, 2018.
  1. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Wow, put a roof rack on Spidey and lost 4 miles/gallon after two tanks measuring. Is that typical?
  2. fuzzy1
    10,552
    Typical? Only if the rack is empty. With skis or bikes or kayaks on the rack, it will lose a lot more.
    #2 fuzzy1, Sep 29, 2018
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    You might try streamlining your Mother-in-Law! …that should help a bit! :rolleyes:
  4. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    spiderman likes this.
  5. n23
    n23 Junior Member
    28
    Tampa, FL
    I'm kinda surprised you only lost 4.
  6. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    What about added wind noise at highway speed?
  7. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    what does it look like? is there a wind deflector in the front?
    Typically I had trouble seeing big difference until the roof top box was on there.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Just one of the those SportRacks. No deflector. I could see that helping and probably make one up next summer. Took it off since I am not kayaking now. lol
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Oh yeah, lots of additional noise in the form of an annoying hum.
    FuelMiser likes this.
  10. wjtracy
    11,368
    3,608
    Northern VA (NoVA)
    Are you kayaking with the Beluga whales?
    Below is what I do these days...you cannot quite do that with a Prius and get the liftback down, but I got the idea from a guy here who stuffs the 10-ft kayak in his Prius and then ties down the liftback. Over 10-ft and you gotta be on top in most cases.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Haven't hit the ocean yet, so no belugas though we saw them this summer in the inlet.
    I got a 10 footer and I would stick it in but I didn't like the idea of lake water all over the interior. :eek:
    We also have a smaller trailer we have been towing behind the wife's Corolla. That works out quit well.
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    You can see in the FE graph when I put on the rack (highlighted) and then off again.[​IMG]
  13. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Why wouldn't you just take them off when not in use?
    For mine, it only takes 10 minutes and works great for carrying 12' and 14' kayaks. I couldn't imagine the straps & pads lasting a long time being exposed to the elements all the time.
  14. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Just had the roof rack and bikes on my 2010 again today. Yes there is a mileage hit, and yes the rack will sing at certain speeds, but it is getting the job done with way better mileage than the average car. The trick is to remove the rack when you don't need it. I used a crayon in the door jams to mark where it should sit on the car so re-attachment is fast and easy.
    Bill the Engineer
    spiderman and Raytheeagle like this.
  15. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    How many miles you got on your Barcelona Red 2010:whistle:?
    Ours just clicked 190k and still going strong (y).
    Bill the Engineer likes this.
  16. john1701a
    12,818
    5,303
    58
    Unnecessary. They have improved recently. Look under the roof door jam of a new Toyota. There's a hole. That matches up perfectly with a pin on the clip for the rack. That ensures correct placement, in addition to providing a slip-proof grip.
  17. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I have for the winter. Mine take a wee bit longer to put on and off.
  18. Bill the Engineer
    1,048
    2,278
    467
    Arouind 100K. My wife telecommutes now, so it only goes on grocery runs and the occasional trip to Lowes.
    Raytheeagle likes this.
  19. wjtracy
    11,368
    3,608
    Northern VA (NoVA)
    Spiderman- Sorry about the quake- OK up there for you?
