2010 Prius Red Brake, Antiskid and ABS Fault
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rossdking, Sep 28, 2018.
  1. rossdking
    rossdking New Member
    Ohio
    So I have a Brake fault an ABS fault and a Antiskid fault on my prius. The battery is fine I have already checked that. I need to scan the codes on the car and could not tell what scanner would work. Can I use and OBDII scanner with ABS function to check the components that are failing or do I really need the Techstream stuff?
    I am an aircraft mechanic I do all my own work I have the Service manual but it wants me to use the Techstream. If I can just buy a Foxwell scanner to do the job I will since I always love new toys for my toolbox I am just looking for a little advice.
    I am thinking it may just be a speed sensor but I don't want to pull every wheel off to use my fluke meter on it. The problem isn't to bad at the moment. my main issue is that with these problems I can not use cruise control.
    any help would be appreciated
  2. Ginto
    Ginto Junior Member
    28
    So not sure if this fits your needs, but yesterday I received
    an update to the ZJB Customer Support Program. This has been around for awhile but was limited to certain production periods. You may want to ask your local dealer if your cars is covered by this updated letter.
    I has all these symptoms and spent a large amount of money getting the Brake booster and pump replaced. I will be contacting Toyota to see if I can get reimbursed.
    Coverage is as follow:
    The Primary Coverage will be offered until November 30, 2019 regardless of mileage.
    After the Primary Period the Secondary Coverage is 10 year 150K miles from first use date.
    Good luck
  3. bisco
    52,354
    you need tech stream. sometimes you can get away with torque, elm, scan gauge, dr prius, etc., but you won't know until you try.
  4. Elektroingenieur
    2,515
    3,287
    Three Touring
    OBD II, as defined in the SAE J1978 and J1979 standards, provides only for engine and emissions-related diagnosis. For other systems on the car, you’ll need a Toyota Techstream diagnostic system or a third-party equivalent that can communicate with the relevant electronic control units (ECUs), such as the skid control ECU for the brake system, or the power management control ECU for the hybrid system. I don’t know which, if any, of Foxwell’s products might have such capabilities.
    For the problem you describe, however, you may not need an external diagnostic tool at all, since the electronically controlled brake system can display its stored diagnostic trouble codes by blinking the ABS warning, brake warning, and slip indicator indicator lights.
    To use this feature, connect a jumper wire between the TC and CG terminals of the data link connector, start the car, and count the blinks. For details, see the Repair Manual topic Brake: Brake Control/Dynamic Control Systems: Electronically Controlled Brake System: DTC Check/Clear, and look under the heading “DTC CHECK/CLEAR (When not Using the Techstream).” @ChapmanF has also posted about this in other threads.
    Robert Holt likes this.
  5. rossdking
    Ohio
    Thanks for the tips I will look into it a bit more during my weekend.
    Elektroingenieur likes this.
  6. rossdking
    Ohio
    Well its a its a right rear speed sensor. So now its off to buy parts as well as a couple of tools.
    My metric tools always get lost since i don't care about them like my other snap on tools.
    Thanks for the advice
  7. Jkan2001
    Jkan2001 Member
    201
    63
    Dallas TX
    Was gonna say speed sensors which I believe is built into the wheel bearing assy or bad ABS pump/recall.
  8. ChapmanF
    18,507
    Before grabbing the wrenches, it's still useful to remember that when the car's computer gives a code that has "speed sensor" as its fortune cookie, that doesn't mean "go replace the speed sensor", it means "I'm getting a weird speed sensor signal, go find out why."
    That involves checking other stuff like connections and wiring, not just jumping to the sensor itself. The Repair Manual will have a sequence of steps to help troubleshoot.
    -Chap
  9. priusvid
    priusvid Junior Member
    32
    Calgary, Alberta
    I have this same problem on my 2010.. did you ever find the solution? Thank you very much
    #9 priusvid, Dec 19, 2018
  10. bisco
    52,354
    speed sensor
  11. priusvid
    32
    Calgary, Alberta
    i was thinking the cruise control might be a clock spring problem as it fixed it on my 2008 but on the 2010 with all of these other issues, looks like it's something else after reading up a little bit...
  12. bisco
    52,354
  13. Mendel Leisk
    41,865
    Make sure all the speed sensors are connected? That's low-hanging-fruit, pretty easy to do even without wheel removal.
