Really annoying when trying to hypermile
Discussion in 'Gen 2 Prius Main Forum' started by First_Time_prius_owner, Oct 1, 2018.
  1. First_Time_prius_owner
    First_Time_prius_owner Junior Member
    28
    toronto
    I know I should just "drive" the car, but when i get close to my house i usually try to drive my gen2 at 50 km or so and keep it to battery so I can get a better mileage rating. The thing is, sometimes the car does not "want" to turn off the engine and go into battery mode. If i come to a total stop, and then slowly accelerate to 25/28 kph it will go to battery. Any suggestions on trying to hypermile the last mile home? all the roads near my house have a speed limit of 50 kph and I usually go 40 (its a residential road, parks close by etc, try not to drive like a maniac)
    DLC82SV likes this.
  2. nssdiver
    nssdiver Me digging' life
    Syracuse, NY
    Four Touring
    You do realize that the next time you start your car, it will try and charge the batteries while the motor is cold and in efficient?
    iPhone ?
    davecook89t and DLC82SV like this.
  3. DLC82SV
    DLC82SV Member
    241
    119
    Mine does everytime regardless...
  4. davecook89t
    davecook89t Senior Member
    1,092
    826
    Washington State, Florida
    Four Touring
    Right, it seems to me that some hypermilers are doing nothing more than trying to earn "bragging rights" by starting off a short trip with a fully charged battery, returning with a relatively depleted one, and reporting their MPG for that trip. I guess it's kind of a fun game that I might be tempted to join, but in the end I think it is really counter-productive for the exact reason you mention.
    DLC82SV likes this.
  5. frodoz737
    frodoz737 Top Wrench
    4,719
    2,517
    33
    Just let the car do it's thing. It's smarter than the average driver when it comes to efficiency and the long term results will be the same. That way you also won't be distracted, obstruct traffic and piss off everyone else.
    #5 frodoz737, Oct 1, 2018
  6. DLC82SV
    DLC82SV Member
    241
    119
    If I park my car with a full battery (SOC 75 - 80%) when I turn it on, it sits and warms up without sending any power to the pack which to me seems like a waste of fuel. I prefer to make sure my battery is depleted to about 50% when I park so that when my car warms up the engine, it's actually sending power to the pack that I can use to drive away, not just burning gas while warming up.
  7. davecook89t
    1,092
    826
    Four Touring
    That's a fair point. I guess the best strategy might be to try to manage our battery's SOC when parking based on weather conditions. If it is likely temperatures will be on the cold side the next time the car is started, perhaps nothing is lost by leaving the car's battery with a relatively low SOC, since the ICE will need to spend more time warming up and might as well charge the battery while doing so, that is presuming the warm-up cycle will not be extended by the need to bring the battery up from a low SOC. As has already been discussed in another thread, it would also be preferable to leave the battery with a low SOC when parking at the top of a hill, if it were known that descending down the hill would provide more regenerative energy than is needed to bring the battery up to a full SOC.
    DLC82SV likes this.
  8. Mendel Leisk
    41,898
    I don't try too hard to keep it battery-only especially considering it'll run the charge down quite fast. I do look for opportune times though: starting off on a slight downhill grade you can sometimes get up to speed completely on the battery. Or if there's a red light ahead, or you're coasting to a slowdown or curve: get off the gas asap, let the engine shut down and then coast up to the slowdown, using the battery a little if needed. Aim to use the brakes as little as possible; use up your momentum.
    #8 Mendel Leisk, Oct 1, 2018
  9. PriusCamper
    PriusCamper Senior Member
    13,054
    5,304
    Pacific Northwest, USA
    Hopefully you've read up on "Pulse & Glide" driving technique... That's the best way to improve MPG... Also to get max MPG you have to use both engine and battery pack together. Trying to force battery use, especially in your last miles home lowers your MPG because then you waste gas because the car has to restore battery pack charge next time you drive when engine is cold and inefficient.
    Or if you get a pack charger from hybrid automotive you could charge your pack up when you get home by plugging it in... Also hybrid assistant phone app has some tools in it that will help guide you to maximize MPG. You'll need to buy a bluetooth device to connect your phone and car: priusapp.com/obd
    But the #1 way to boost MPG is to keep as high as tire pressure as you feel comfortable with...
  10. bisco
    52,386
    not that i can think of. you'd be better served to do your hyper miling during normal back road driving.
    DLC82SV and davecook89t like this.
  11. fuzzy1
    10,603
    Have you, or anyone else, done any measurements to see if anything is saved or gained by this?
    You mustn't assume that 'idling' with battery charging takes no more fuel than bare 'idling' without such charging. Charging from a spinning a generator is never free, it requires extra torque and power from some prime mover. For a motor, that requires extra fuel compared to idling unloaded.
    When refilling the Prius traction battery, this extra fuel must be balanced against whatever savings happened while depleting the battery previously. Considering that this depletion / recharge process means laundering the energy through additional lossy conversion steps, it is not at all obvious that this balance will turn out to be positive or even neutral.
    nssdiver and davecook89t like this.
  12. First_Time_prius_owner
    28
    toronto
    Thank you for all the replies, much appreciated. So overall, I think what I will do is "just let the car do it's thing" and measure the mpg long term average, and prioritize momentum vs brakes as long as it is safe. Will stick to hypermiling on regular roads!
  13. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    I'm about ready to throw something!! :ROFLMAO: Stop making it all complicated, and just drive the damn car! Leave it in regular D mode, and don't mess with it. I don't know about the earlier generations of Prius, but when I drive my car normally the gas mileage is actually better! The heck with all that silly "hypermiling" stuff! SHEESH. :LOL:
    People are getting 45-55 mpg, and that's not good enough??? Buy a bicycle (and get some exercise. :D)
    EDIT: Nothing personal against the OP. Maybe the Gen2 and 3 need to be driven differently? But I sure see a lot of earlier Gens blowing by me doing about 85 on the freeway! :eek: Just drive it, and have some fun! I'm always in PWR mode.
    #13 Starship16, Oct 1, 2018
  14. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    There's your fuel waster right there. Start it and go. The system will use the battery to reduce engine load while it warms up, so as they say, just drive it. This car is seriously smart.
  15. First_Time_prius_owner
    28
    toronto
    Yes that is the plan now :) just drive it.. you know what..its the damned center screen! if i could just cover it away I would not think about it so much - realtime mpg feedback is maybe too much feedback ;)
    @jerrymildred is that SERIOUSLY you mpg? 84.8 ?! wow!!!
  16. First_Time_prius_owner
    28
    toronto
    The newer prii have a bigger engine (1.8 vs 1.5) and better hybrid efficiency. I think you get a few more mpg's out of it without as much effort.. I think a 2018 prius prime with a bike rack (and a bike on it) is a great idea :) haha
    Starship16 and davecook89t like this.
  17. PriusCamper
    13,054
    5,304
    Yes, but a Prius is a thinking person's car and many new owners, at least at first, tend to over think it... Myself included in the first few months, from installing the stealth mode wires to re-activate electric motor only option like on non US cars, seeing what use driving in B mode is, trying to keep charge bars in green no matter how much gas I waste...
    All these things are quite common to try at first... Then once you think it thru it's not something you again do.
  18. fuzzy1
    10,603
    Note that he has a plug-in model, so that figure is not comparable to my and your non-plug-ins.
    If you get that Prime you thought about in your next post, you can easily beat him. That is, unless you put the roof rack and bike on, that changes the picture significantly.
    Starship16, DLC82SV and jerrymildred like this.
  19. jerrymildred
    11,517
    14,157
    Tampa, FL
    As @fuzzy1 said, it's a plug in. And a Prime leaves this thing in the dust for gas mileage. Usually, in hybrid mode I get 55-65 mpg. Last weekend, we did a road trip that was mostly interstate. 90 miles + each way starting with a full battery. Got 60 mpg going out and 61 mpg coming home. Interstate driving was about 55 mpg at 70 mph.
    If not for road trips, I'd probably be averaging about 110-130 mpg.
    Starship16, DLC82SV and fuzzy1 like this.
  20. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    I personally think there's one major factor concerning my gas mileage. My lead foot!
