What is your record for consecutive days with only EV mode?
Discussion in 'Prime Main Forum (2017-2022)' started by coach81, Oct 2, 2018.
  1. coach81
    coach81 Active Member
    758
    116
    Louisiana
    How many days have you been able to drive ONLY in EV mode.. no gas used???
  2. Salamander_King
    Salamander_King Senior Member
    11,023
    8,960
    New England
    1 day... My daily commute is 38 miles (both ways, no charging at work). I have made ALL EV for this commute only twice in last 1 year of PRIME ownership. :cry:
    #2 Salamander_King, Oct 2, 2018
    coach81 likes this.
  3. JonW
    JonW Member
    55
    65
    Texas, USA
    Not counting when temps are extremely high or low - I tend to go about a month without using gas since my daily commute is 50 miles (25 miles one way) and I'm able to charge at work. That monthly gas expenditure is my monthly trip to the store to re-stock my food supplies.
    coach81 likes this.
  4. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    0. My commute is 75 miles..
  5. AmazingPriusPrime
    AmazingPriusPrime Junior Member
    Northwest
    Hoping for 1 month straight but it is getting difficult since my daily commute is 45 miles and I can charge both at work & home but I miss at-least once a week to charge at work for various reasons so the best I got as of now is like 4 days.
    coach81 likes this.
  6. bisco
    52,271
    geguia and coach81 like this.
  7. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    coach81 likes this.
  8. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    Probably 3 days since my commute is 55 miles. I guess I'm in the same boat as a lot of others. :(
    coach81 likes this.
  9. coach81
    758
    116
    Louisiana
    WOW.. that is awesome!!!!
    So Husk, what happens to the gas for that long a time, does the car eventually just burn some of it, or did your gas meter just stay at full?
    Also.. did it get to be a "pain" to always plug it in everyday??
  10. benagi
    benagi Active Member
    525
    280
    Utah
    I usually go 29 days. Then on the last day of the month I like to burn a little gas. Also don’t care about eco scores on the last day of the month because everything starts all over on the first of the month. So far I have only burned a 1/4 tank in 10 months. My commute is only 22 miles round trip which helps.
    coach81 likes this.
  11. coach81
    758
    116
    Louisiana
    Thanks Benagi, this is how I think I would end up if / when I get a Prius. Have you noticed a substantial increase in your electric bill?
  12. DavidA
    2,345
    1,821
    Chicago western burbs
    125*. May 12, 2018 to Sept. 14, 2018. Commute round trip is 2.5 miles, which gives me the opportunity to go electric most always, at least until the car is driven on a cross country trip.
    * I might have used about a cup of gas somewhere in there doing a 35 mile errand.
    benagi and coach81 like this.
  13. MNdriver
    MNdriver Senior Member
    549
    577
    I’ve never counted in terms of days. But I last bought gas in December, so I’ve had very long stretches without using any gas. Then again, I have a short commute and not much of a social life.
    coach81 likes this.
  14. coach81
    758
    116
    Louisiana
    Yes!!! This is the kind of feedback that fires me up.... (y)
  15. huskers
    2,544
    2,487
    Nebraska
    See below.
    #15 huskers, Oct 3, 2018
  16. huskers
    2,544
    2,487
    Nebraska
    Does not burn any. Just stays at full. All of my trips around town are EV. Only use gas when I have to travel which is not often. Gas for months unused seems to be fine. I would not want to go over 6 months and there is a difference between winter blend and summer blend so there is that. Not a pain at all plugging in. Sure beats nozzling in. Personally, I have not noticed any significant change in my power bill from pre Prime days.
    coach81 likes this.
  17. Mark57
    2,945
    2,740
    OK
    42 days for me. One time deal. I normally have once weekly round trips that are about 115 miles.
  18. geguia
    geguia Active Member
    210
    108
    los angeles
    5 days typically - my commute is 10 miles and i have a charger at work but weekends i drive more then hit the gas.
    I would do great if i had an all electric car.
  19. Spidey71
    Spidey71 Member
    60
    49
    Alberta, Canada
    2018 Prius Prime
    About 2 weeks. We've taken some pretty long road trips as well and are currently averaging 118 mpg since new.
  20. coach81
    758
    116
    Louisiana
