Tire pressure - tire wear
Discussion in 'Gen 3 Prius Fuel Economy' started by Oddfodder, Aug 23, 2018.
  1. fuzzy1
    10,588
    Electric tools are certainly a major strain saver for big jobs. I need them to keep from aggravating RSI (repetitive strain) injuries, not caused by overuse of manual tools. And non-corded versions are both less cumbersome, and not limited by extension cord range, certainly helpful on the farm where the nearest electric outlet may be within 100 feet, or beyond a mile.
    But topping off a car tire with a manual bike pump is neither difficult nor time consuming for an able bodied adult, unless they are using the wrong tools. It is certainly much quicker than having to top off an electric device's battery on a charger beforehand.
    Lightning Racer likes this.
  2. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Had to replace a tire months ago due to actual razor blades purposely set up side down on the railroad crossings. The tire company replaced the messed up tire and said the other 3 tires are wearing evenly. I've been told not do this many times but I inflate all tires to 44psi, even during morning summers and they balloon up to 51psi after driving for couple hours in 105 degree temp. People here say it will blow up and bad for tires. I won't get into explaining why it's safe to do that, but not today because I have red wine to finish.
  3. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    The reason I drive a Prius is to get the best mpg's possible, and tire pressure is part of the formula, on a bicycle you want to pump up to the point that you start to lose traction on bumps, I find about 135-140 is good, on a car like the Prius 40-45 is good, higher would be better but comfort comes into play, at 42-40 the car stoppes faster and is overall safer, remember, the sidewall recommendation is 1/2 the bursting pressure,just like bicycle tires.
    My bicycle tires have a recommendation of 220psi. Tofu.
    Oddfodder likes this.
  4. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    My MPG never changed after I increased the PSI up to 45. I drove for about 3 months at that pressure. (Michelin Premier tires.) Dropped it down to 42, to reduce some of the harshness. But it was still bad. Lots of clanks and clunks from the suspension, and every small bump was magnified.
    Now I'm back at factory PSI specs, and the ride is much smoother. No more teeth-rattling jolts. No more groans from the suspension, and MPG is the same as it always was.
    Maybe the trie tread wear will not be as long? I don't mind. That's Ok. A smoother ride and reduced noise is more important to me. And 55-57 MPG is just fine for my needs.
    #64 Starship16, Oct 6, 2018
  5. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Turd gen?
  6. Starship16
    1,348
    1,455
    Beach Christmas
    Lexus RX 450h
  7. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Youre comparing tire wear, inflation & mpg from that car to a turd gen? Huge difference, apples vs oranges.
  8. Oddfodder
    Oddfodder New Member
    28
    Freiburg, Germany
    Starship16 and Mendel Leisk like this.
  9. Oddfodder
    28
    Freiburg, Germany
    Also really interesting. Amazing how different drivers have such different results. Though obviously weather and driving conditions must play a big role.
  10. Starship16
    1,348
    1,455
    Beach Christmas
    First of all I do not have a third GEN.
    And second of all, I was just kidding about the Lexus. But I am at the auto show I'm going to look at them.
    Here is a picture of Mendel's Mazda CX 5. Beautiful.
  11. Mendel Leisk
    41,826
    Hey that's the colour too. Touch up paint is a total pain though...
    Starship16 likes this.
  12. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    I get batteries for my Craftsman electric hedge clipper and string trimmer off Amazon. 1/2 the price of my now closed Sears store.
  13. Starship16
    1,348
    1,455
    Beach Christmas
    I would like to know from those who over inflate their tires, exactly what kind of increase in mpg are they getting? Two more MPG? Three more?
    And do they have 15 inch tires or 17 inch?
    The harsh, firm, and noisy ride that I experienced when going to 42 or 45 psi...it is just not worth it. But I am only talking about my Gen4 car, with my Michelin tires. Factory PSI specs are just fine for it. And so is 57 MPG. (AC on full-time, and using PWR mode, and driving like nuts! :LOL: (y))
    #73 Starship16, Oct 6, 2018
  14. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    4 gen, use the other forum. This is turd gen.
  15. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    No, it's a discussion about tire pressure, turd.
    #75 Usle, Oct 6, 2018
  16. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    This is turd gen discussion my turd.
  17. Starship16
    1,348
    1,455
    Beach Christmas
    :ROFLMAO: (y)
    We will have to excuse grid... He's PWD again. Posting while drunk. :LOL:
    (Share some of that Jack Daniel's. ;))
