So, Are we Still in Love?
Discussion in 'Prime Main Forum (2017-2022)' started by Prime Example, Sep 3, 2017.
  1. Prodigyplace
    12,633
    11,810
    Central Virginia
    Not THAT far south.
  2. Prodigyplace
    12,633
    11,810
    Central Virginia
  3. coach81
    coach81 Active Member
    758
    116
    Louisiana
    Depending on the storm... if it is a "bad one" cat 3 or higher, yeah we would take both vehicles and we would leave as early as possible.
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    This is one main reason I took my Prime to the eclipse. I filled up in the morning, giving me a range of well over 800 miles (I got 75mpg actual on the way home), and plenty of staying power *it took 10 hours to get home, and I only used about 1/3 of a tank).
    In a crisis, the energy you have with you is by far the most reliable energy.
    CraigCSJ likes this.
  5. coach81
    758
    116
    Louisiana
    Thus my concern over the Leaf here.
  6. Zed Ruhlen
    Zed Ruhlen Active Member
    247
    138
    Hood River, OR
    2018 Prius Prime
    Well of course I knew it when I bought the car. Doesn't mean it was a good engineering/design choice nor that I like the choice. Any car has a number of trade-offs that you have to figure into your buying decision. Many other things outweigh this particular negative. That doesn't mean I have to like it. I also hate the shifter and the centered dash. More stupid design decisions. My Leaf also had the stupid pointless "gear shift" knob that manages to be both worthless and a pain in the rear at the same time. At least the Prime has the thing on the dash instead of the center console.
    Sedans have a much more steeply raked rear window so rain naturally falls off the window whereas a hatchback the drops stay on the mostly flat surface and the prius is one of the most horizontal of hatches. Every morning now my rear window is covered with dew and you can't see anything out of it. Its annoying to have to manually clear the thing in the morning and it will be worse once frost comes because when I leave home the window will be ice until the defroster thaws it. I personally think it is a major SAFETY concern.
    #146 Zed Ruhlen, Oct 13, 2018
  7. DavidA
    2,345
    1,821
    Chicago western burbs
    Some actually liked the shifter in the Prius Gen3 "bridge." I did. Others didn't. My wife didn't. Then she goes out and buys a used 2013 Lexus 200h. Bridge again and shifter smack dab in the middle of it. My Prime, of course, moved it back up there to the dash. I tolerate it.
  8. Salamander_King
    Salamander_King Senior Member
    11,023
    8,963
    New England
    While I agree with you that "the prius is one of the most horizontal of hatches", I think in general hatchback cars have more vertical rear windows than sedan counterpart, at least for the cars I have seen. See picture of Corolla sedan (top) without rear wiper and newly released Corolla Hatchback (bottom) with rear wiper. Most of hatchback I have seen are more like wagon than regular sedan.
    My first car with rear window wiper was SUV and then minivan. Both of them had fairly vertical rear window, yet came with wiper, while more horizontal rear windows on sedans and coupe did not. At the time, I thought sedans and coupe are the ones that would benefit from having rear wiper not hatchback on cars, SUV, and minivans. As I pointed out to you, sedan corolla, and AFAIK all other Toyota sedans do not come with rear window wipers, and Prius (and Prime) in it's profile style, is the only hatchback that really looks like sedan to me. I think omission of rear wiper from most sedan and coupe are for styling (and probably also for aerodynamics and cost reduction for some models). Not having rear wipe was never an issue for me, but again if you really thought having rear wiper is so important for your driving condition, why did you buy PRIME in the first place?
  9. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    Clearly, you haven't noticed what's happened with sedans. Some literally have slopes just like hatchbacks now.
    As for safety, if you only ever clear off the part with the wiper, you're compromising your own visibility. You should always wipe off the entire rear window before driving.
  10. Mendel Leisk
    41,830
    I've always had the sense the typical hatchback had a more steeply sloped back window, and accordingly gets dirtier faster, and that was why they usually had a wiper. I'll notice the lower (vertical) glass on our Prius rear hatch gets dirty very fast, faster than the upper (more sloped) glass, due I think to air currents swirling behind a vertical surface, leaving more deposits.
    Still, the Prius rear wiper sweeps such a small area, it's not much better than nothing.
    Salamander_King likes this.
  11. coach81
    758
    116
    Louisiana
    Which brings me to this question... how does the "touchless carwash" do with the sloped glass and back of the prime?
  12. Lee Jay
    5,850
    4,036
    I used it so much in my 2004 that I replaced it 6 times. It's massively better than nothing. In fact, it worked extremely well.
    Zed Ruhlen and Mendel Leisk like this.
  13. Salamander_King
    11,023
    8,963
    New England
    It seems to be all about personal preference. Having driven rear wiper-less sedan for a long time, not having rear wiper is non-issue for me. With Gen3 Prius, I have used rear wiper only a few times just because it was equipped with it, but not having that option on Prime does not bother me at all, even though we get fair amount of snow, freezing rain and frost issues in our climate.
    #153 Salamander_King, Oct 13, 2018
    benagi likes this.
  14. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    Because I liked so much of the other features. It's an amazing car but that doesn't mean I'm going to give Toyota a pass on a dumb design decision. I don't buy the cost angle on a 25-35k car with a carbon fiber rear hatch. I mean that rear window surely cost way more than a normal window with a wiper.
    My point on the shifter is that it is basically a useless knob. You could have had a row of buttons instead or a rotary switch or almost anything. It's not like you have any mechanical connection to a transmission. Also the "return to center" behavior means that you can't just look at it and know what gear you are in and why the heck is "Park" a separate button? If Toyota really wanted a knob they could have used any number of stock parts from other cars.
    #154 Zed Ruhlen, Oct 13, 2018
  15. Tideland Prius
    16,604
    The washing part is fine. It's usually the drying part. The rear is always wet.
    coach81 likes this.
  16. 2015BlizzardPriusFour
    2015BlizzardPriusFour Active Member
    171
    142
    Central Valley CA
    Though true for the most part, there’s a few cars that are very similar between sedan and hatchback versions.
    Like Our old Mazda 6 for example. At a quick glance looked identical other than hatch having a rear wiper.
    iPad ?
  17. Salamander_King
    11,023
    8,963
    New England
    Is Mazda 6 sedan without rear wiper? If so, again, it seems standard not to have rear wiper on sedan regardless of slope of the rear window. Now, I have no idea, why hatchback comes standard with rear wiper. Mendel's reasoning would not apply on this one.
  18. Tideland Prius
    16,604
    Bottom one is the hatchback (liftback). I love that generation. There was also a wagon version but only came with the 220hp V6.
    Yes. Only in Japan do sedans come with a rear wiper. (AFAIK)
  19. 2015BlizzardPriusFour
    171
    142
    Central Valley CA
    Agree, we miss ours a lot. Had the 4-cyl. We got sideswiped and spun, then pushed by a pump truck for about 150 ft sideways. Was $1k shy of being totaled but repairs were done on the cheap and felt it never drove the same. Traded it in on our first Prius. (2011 two in gold)
    Fun fact on the hatch back (lift back), you can actually fit a full-size 150cc scooter in the back and close the trunk with seats folded down.
    iPad ?
    benagi and Tideland Prius like this.
  20. Tideland Prius
    16,604
    Wow!
