Prius Clear Coat Bubbling and Peeling - 2008 Light Green
Discussion in 'Gen 2 Prius Main Forum' started by coolprius_saidnobody, Oct 13, 2018.
  1. coolprius_saidnobody
    Arizona
    The clear coat on my 2008 Toyota Prius suddenly started peeling about 2 months ago. It started on the roof and now I am noticing spots on the hood, and I expect it will eventually affect the entire car. I called Toyota and they said it is not a known issue, and they convinced me it was a one-off problem. Today, I saw TWO 2008 Prius' in my city with the same exact problem, and oddly enough they were both the same color as mine, light green. Also, there is at least one other post in this forum with the issue, also a light green Prius.
    Please, if you also have this issue, let me know below. And please call Toyota to report it.
    Sheri Shirey likes this.
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Since you live in Arizona it’s very sunny there. Is it parked in the shade? How often have you waxed it?
  3. bisco
    48,996
    welcome
    my daughter has a 2008 light green
    not sure what you can accomplish with toyota, it is 10 years old
    all the best!(y)
    Skibob and PriusCamper like this.
  4. PriusCamper
    PriusCamper Senior Member
    10,927
    4,430
    Pacific Northwest, USA
    After 10 years, this type of damage can only be avoided if you regularly wash, polish and wax and stay parked in shade as often as possible...
    Steph1972, psymon100 and Mendel Leisk like this.
  5. C Rider
    C Rider New Member
    Ohio
    I have a 2006 that is the same color. Mine has clear coat damage on the roof and spoiler. Mine doesn't look nearly as bad as yours though. I would guess it has to do with where you park it and how you maintained the exterior.
    bisco and PriusCamper like this.
  6. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    Usually the lighter colors like Silver Pine Mica don't get it so bad. Barcelona Red gets it something fierce. Lots of Toyotas and Nissans get it real bad around here. Maybe the clear coats the Japanese used in this era just weren't UV resistant enough.
    Not much you can do about it now, short of a full repaint. Sorry.
    srellim234, PriusCamper and bisco like this.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Poorly maintained paint.
    PriusCamper likes this.
  8. JC91006
    JC91006 Senior Member
    16,470
    8,383
    You'll see lots of paint problems on the roof, spoiler, and hood. Other parts will hold up much better.
    You can paint the damage parts or get a vinyl wrap, which is often cheaper
    srellim234 likes this.
  9. srellim234
    srellim234 Senior Member
    1,193
    1,681
    Laughlin, Nevada
    Our 2008's spoiler is looking pretty bad. The fading started about two years ago but it has really accelerated this year. On a 10 year old car I'm not looking to pay through the nose for a professional job to fix it. Just something that looks halfway decent and I can get a few years out of. The plan is to repaint it while the car is down in December for the next Prolong battery maintenance. I've been looking at some online videos and it doesn't look too difficult as long as I'm careful and have some patience. Paint + clear coat sprays should cost less than $20 at the local auto parts store.
    By 9 years old the blue paint job on the first Prius we owned was completely shot in all three of the areas you named....the roof, spoiler and hood.
  10. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    You can get 1 stage paint mixed into spray cans at good paint shops. I did that for my daughters Nissan Pathfinder. Had a special 2 year only paint color. They had no problem mixing up the color. They put the pigment into a spray can and mix it up.
    SFO likes this.
  11. Melinda Ryan
    Melinda Ryan New Member
    Fort Lauderdale
    I have a gold 2008 Prius and it is having the same issue. I have maintained it with regular washing and waxing which hasn’t made a difference. The spoiler was the first to show paint fading. The paint on the roof is crazing and the hood is showing small areas where the paint is starting to come off but no crazing. I live in south Florida and the car has always been parked outside. My headlights are also fading. I had them buffed out for what was supposed to be a lifetime warranty and they continue to fade and need rebuffing on a regular basis.
  12. coolprius_saidnobody
    Arizona
    Thanks. Is the clear coat bubbling and peeling on hers?
    When I called Toyota, they said this was unusual, even for Arizona, but that this wasn’t a known issue to them and must be a one off thing. I’ve started seeing this issue regularly on other people’s cars just driving around town and it’s ALWAYS a 2008 Light Green Prius.. no other year and no other color. Please report to Toyota when you have a chance!
    Please report to Toyota when you have a chance. When I called they told me this was unusual, even for Az, but they hadn’t had any other reports of it. Thanks for your reply.
    #12 coolprius_saidnobody, Mar 25, 2019
  13. Paul R. Haller
    285
    Walnut Creek
    I have an O6 in pine mica. The spoiler is in bad shape. You will get no accommodation from Toyota on a 10 year old car.
  14. bisco
    48,996
    no, her paint is fine. and it has never been washed or waxed, except rain, snow and ice.
    coolprius_saidnobody likes this.
  15. egg_salad
    545
    426
    Las Vegas, NV
    My '08 is in silver pine mica and I have absolutely no paint issues. According to the CarFax, the car has spent it's whole life in AZ and NV. I'm not sure how my car has escaped these issues.
  16. coolprius_saidnobody
    Arizona
    I’m sure you’re right. I’m just frustrated that it seems to be only this year, and only this color that has the issue.
  17. 09Prius2
    09Prius2 Member
    201
    88
    FL
    I had one green one yep same thing. The roof is a good candidate for a spray experiment. They sell mix to factory code matched paint online with clear coat already mixed in a can. Plastic sheets and masking tape at dollar tree, probably sandpaper too. If it doesnt turn out, its just the roof. If it does turn out you can do the rest piece by piece for a couple hundred so long as its the same color you shouldn't need to buy a ton of paint.
  18. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    My wife's pine mica '07 isn't too bad. Not as bad as yours by a long shot. Even my barcelona red '05 didn't get that bad and that color was notorious for blistering. Only bad parts on my wife's car, other than some chips on the plastic parts) are the door handles and spoiler. The handles we all crinkled. I stuck plastic chrome covers on them. The spoiler was badly faded. I sanded it down and painted it with primer, gloss black, and clear. It came out pretty nice except for some lint that landed in it while the pain was wet. Grrrr!
  19. srellim234
    1,193
    1,681
    Laughlin, Nevada
    Since only the top of the spoiler was oxidizing I decided, after looking at some videos of how to do it, paint the top of my spoiler without taking it off the car. One day in my garage, light wet sanding, a spray can of Duplicolor in Barcelona Red plus a spray can of Duplicolor Clear Coat and masking of the back of the car to protect it from overspray. Total cost to do it turned out to be less than $25 for the paint and sandpaper at Pep Boys with enough left over to do it one or two more times.
    I've already gotten some complements on the improvement from family and friends. The new paint matches the rest of the car well and doesn't look "off" like most section paint jobs do. Being careful to spray very lightly and evenly while applying multiple coats there's not even a visible seam between the newly painted area and the original paint job. For sure, it's not professional body shop "baked on" quality but after all the car is 11 years old. I'm not looking for showroom brilliance, just functionality and a decent appearance. With a cost of only $10 worth of supplies actually used for the job I don't even mind if I have to do it again in a couple of years.
  20. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    Pics:whistle:?
    Always good to see everyone’s handiwork(y).
    Mendel Leisk, Skibob and srellim234 like this.
