Rubber roof moldings coming loose
Discussion in 'Prius c Main Forum' started by Nate the Skate, Sep 15, 2018.
  1. Nate the Skate
    Nate the Skate New Member
    27
    Houston, TX
    2014 Prius c
    I have a 2014 Prius C. The long, thin, black, rubber moldings along the roof rails are coming loose at the car wash.
    There are two attachment points, front and rear, where they snap in. The front ones are holding, for now - but the rear comes loose every time. I'm using this car to Uber so frequent washes are a must. I tried to use the masking tape they use on rear wiper, but it didn't work.
    Any ideas? I've read old posts on this and the strips are $70 if you lose one.
    Thanks.
    EdwardCA likes this.
    52,070
    maybe start with just a dab of silicone, and keep adding until it won't come off.
    Talha Maqsood likes this.
  3. Nate the Skate
    27
    Houston, TX
    2014 Prius c
    Thanks bisco. You always seem around to help. :)
    Would you add it to the molding, or the clip on the actual body?
  4. bisco
    52,070
    either way, it will touch both when connected. you want enough to hold up through the car wash, but not so much that it would prevent you from removing them.
    although, i have never had occasion to remove, maybe for a paint job?
    is there any way to bend the clip to make it tighter?
  5. Nate the Skate
    27
    Houston, TX
    2014 Prius c
    Thanks again.
    As soon as it cools down I'll take a look at the clip to see if it can be bent.
  6. Talha Maqsood
    Talha Maqsood Member
    46
    26
    Pakistan
    2015 Aqua
    Bisco is right, just a dab of silicone should do the job,
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    You could simply call a few body shops and ask what they recommend. Since my guess is they have had to replace similar on many vehicles as part of their operation.
    They are probably going to say glue or silicone, but they might have a definitive "trick" to it.
    Usually over the phone, people are willing to give the advice for free.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    The rubber strip shrinks along it's whole length.
    It is supposed to "snap" into the channel the whole way.
    What is really needed is some "glue" down both sides for the whole length.
    On my daughters C, they are still firmly attached at both ends but flap around in the middle.
  9. dubit
    dubit Senior Member
    850
    538
    Indiana
    2016 Prius c
    Left side was replaced under warranty on my C. When we installed the new strip, we also put a thin layer of 3M glue in the rubber channel on the strip itself. When I got home I removed the right side and used Gorilla glue. No problems since. And your correct about the car wash. That's when i noticed it also.
  10. Nate the Skate
    27
    Houston, TX
    2014 Prius c
    I wanted to update this.
    I had to have some minor body work done and I decided to ask him to fix the rubber strips. He said he preferred a different glue, in lieu of silicone. They ain't going anywhere anymore, that's for sure. Driver's side mirror gets folded in going thru carwash, but that's it.
    dubit and bisco like this.
  11. EdwardCA
    EdwardCA New Member
    2015 Prius c
    I have a 2015 Prius C 3 and going through the car wash, years ago, it came out with the roof moldings flapping around. From then on I have them taped down before going through the wash. However, now, in windy conditions on the road, I will hear them flapping around against the car and have to pullover and fix them back in. Definitely a design flaw. They're a little loose all the time now. I always wondered if I could just gorilla glue them on, or if they'd ever need to be removed (like for paint). Luckily I found this forum and now I'll try the glue. Hopefully, if I ever need to pain, it won't be too much of a hassle.
  12. Mendel Leisk
    41,628
    Whenever I want to glue (or lube) a smaller piece being placed on a larger area, I've found it's best to put the goop on the smaller piece, then it's right where it needs to be.
    Brake pad shims are similar: apply the lube to the shim, then place it on the back of pad.
    BTW: it's good to pull those strips right off once in a while, clean out the troughs, deal with any rust, apply a car wax.
