Small leafs collecting in the gap around the rear window
Discussion in 'Prime Main Forum (2017-2022)' started by schja01, Oct 17, 2018.
  1. schja01
    schja01 Senior Member
    1,841
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    05079EBD-4E61-4C47-B867-F5F36C4060BA.jpeg It’s autumn here in the Midwest. I’ve noticed tiny leafs collecting in the gap around the rear window. Short of using compressed air which I don’t have I’d need tweezers to remove them.
    If I just leave them they seem to fall further down and no longer are visible.
    Will they eventually flush out somehow? Will they disintegrate into a muck and contribute to premature corrosion? Other?
    Any insight appreciated.
    J
  2. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    I have the same problem with pine needles. I use my shop vac that seems to remove them. Also works under the hood around the wipers and under the rear hatch.
    Mendel Leisk and schja01 like this.
  3. schja01
    1,841
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Great suggestion. Thanks.
  4. KCWhitney
    KCWhitney Active Member
    140
    118
    Connecticut
    2025 Prius Plug-in
    I think you mean small leaves.
    I can imagine small Leaf drivers collecting around your window, looking in with wonder in their eyes, though.
    Mendel Leisk, EazyPeazy and huskers like this.
  5. schja01
    1,841
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    I gave that a lot of thought when composing my post.
    Leaves is the plural of Leaf.
    Unfortunately it's too late to change my original post. :(
    Which also begs the question are multiple Nissan Leafs called Nissan Leaves?
    J
    Leaves | Define Leaves at Dictionary.com
    #5 schja01, Oct 18, 2018
  6. coach81
    coach81 Active Member
    758
    116
    Louisiana
    But what if the tiny leaves run out of juice???
  7. huskers
    huskers Senior Member
    2,546
    2,487
    Nebraska
    They are just jealous.
  8. Flaming
    Flaming Active Member
    138
    123
    QC , Canada
    Technology
    You need to keep an eye and keep this area (gap) clean , in the middle there is a drain for the water and the water outlet is a tiny hole just under third brake light on the trunk. I use a thin plastic card (credit card type) and slide it into the slot to pull out the s**t. ;)
    #8 Flaming, Oct 18, 2018
  9. coach81
    758
    116
    Louisiana
    That sounds like a pain in the....
  10. EazyPeazy
    EazyPeazy Member
    110
    83
    New York
    Too bad I don’t carry around a compressed air gun. Lol.
  11. Mendel Leisk
    41,861
    Similar problems with a 3rd gen, I've used a shop vac, but I don't think I always get them all. Another trick you might try is a piece of twine, sometimes you kinda floss stuff out.
  12. coach81
    758
    116
    Louisiana
    "Hold on honey.... gotta floss my Prime".... LOL
    Curlyone and Mendel Leisk like this.
