Coastal EV Mod
Discussion in 'Gen 2 Prius Technical Discussion' started by ibcs, Aug 14, 2006.
  1. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    When using the EV Mod from Coastal at the point it dis-engages you get three beeps. Does anyone know how to disable the beeps.
    My wife find it annoying though she still has not driven the Prius since January. Too complicated for her.
    Thanks,
    ---Kent
  2. Tideland Prius
    16,540
    ehh.. no. The beeps tell you you're out of EV and it's probably the only way (unless you accelerate hard). If you want to disengage it, pull the CC switch for 2 secs instead of letting the computer disengage it.
  3. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    Thanks for the quick response. I knew I could disengage manually, but I thought I would give my wife a break. She'll just live with it.
    ---Kent
