MFD replacement for Gen 2. Who did you buy yours from?
Discussion in 'Gen 2 Prius Main Forum' started by JBuckPrius, Oct 17, 2018.
Tags:
  1. JBuckPrius
    JBuckPrius Junior Member
    64
    Knoxville, TN
    Great. Thanks.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,092
    Columbia, SC
    my 2007 touring with BU camera and no nav has a 86110-47230. I do not know if 2006 and 2007 used the same model or not. If you're going to buy one, your best move is to pop it out and check. It can literally be done in 10 minutes. Different part numbers have slightly different connector/plug shapes.
    #22 TMR-JWAP, Oct 19, 2018
    JBuckPrius likes this.
  3. JBuckPrius
    64
    Knoxville, TN
    What is the model number? How much do you want for it?
  4. boppo
    boppo Active Member
    799
    139
    Owego, NY
    it's from a 2005 without maps, P/N 86110-47081. I would like 100.00 for it.
    thanks
    #24 boppo, Oct 29, 2018
  5. JBuckPrius
    64
    Knoxville, TN
    Thanks for the info. Sorry for such a long time before replying. I still have not taken the dash apart to check the part number. When I do Ill contact you to see if yours is still available.
  6. boppo
    boppo Active Member
    799
    139
    Owego, NY
    No problem,
    thanks
