Engine light is ON
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by syscon, Sep 26, 2018.
  1. syscon
    syscon Member
    329
    43
    Edm. Alberta
    I have Prius V (2012) ~127K Km (about 80K mi). My Engine light went ON.
    I check the oil, it was very low; added 1L 0-W20 but the light was still ON. I disconnected the battery negative terminal for 5min.; connected back and the Engine Light went away. Hope, it stays this way.
    #1 syscon, Sep 26, 2018
  2. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Though, I'm surprised, I had an oil changed at 119K km now I have 127K Km made only 8K km (5K mi) on this oil and the oil was very low. Previously I made almost 16K km between oil changes and never had to add any oil.
  3. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    The engine light signifies a code has been stored. The fact that you disconnected the battery “temporarily” fixed the problem until it happens again. You need to scan the vehicle or have it scanned to determine the real cause.
  4. bisco
    52,386
    you're right around the mileage where the egr clogs and blows the head gasket.
    it's time to get serious about your maintenance before you get a huge repair bill.
  5. rjparker
    10,503
    6,593
    Highly unlikely low oil caused a check engine. Most auto supplies will scan and clear for free although you have brute force cleared it now and have cleared all engine self tuning parameters. It could be one of a thousand codes from the gas cap being loose to excessive engine temp. Find out next time. If it blinks shutdown immediately.
  6. syscon
    syscon Member
    329
    43
    Edm. Alberta
  7. bisco
    52,386
    get the mini vci with tech stream if you can. cheap money, but you need a compatible laptop.
    otherwise, torque app is decent.
    that way, you will have more than check engine reading ability for the future.
  8. bisco
    52,386
    have you checked the gas cap?
  9. syscon
    syscon Member
    329
    43
    Edm. Alberta
    I did, the gas cap is on. I just fill-up the gas and the light is still ON.
  10. bisco
    52,386
    if the cap was loose, it takes a few days for the light to go out. otherwise, it is more significant.
  11. syscon
    syscon Member
    329
    43
    Edm. Alberta
    I just ordered ELM 327 BT adapter to check the codes much cheaper than Dealer 1hr. service :-/
    Though, it might have to do something with the gas tank. When I'm putting gas-in at the pump the spout gets easily triggered and turn OFF so I have to put the gas IN very slowly. Before I could squeeze the pup handle all the way and wait till it turn itself off.
  12. syscon
    syscon Member
    329
    43
    Edm. Alberta
    I re-setted the light by disconnecting the battery cable again. I think my scan tool will come before the light would reset itself (it it was a gas cap).
  13. syscon
    syscon Member
    329
    43
    Edm. Alberta
    I did not scan the codes yet, but it seems to me I have a evaporative emissions problem in my fuel tank. When I put the gas IN " fuel nozzle keeps clicking off. " Any idea how to fix it?
  14. bisco
    52,386
    no. you'll have to get the codes, then follow the service manual troubleshooting repair tree.
  15. mikefocke
    4,040
    1,839
    Sanford, NC
    Turning the CEL off does nothing to fix the underlying problem. Get it read even if you have to go to an auto parts store and have them read the codes. They often do it for free.
  16. syscon
    syscon Member
    329
    43
    Edm. Alberta
    I got the scanner today ELM327C (blue tooth) and using torque software I printed codes:
    P043e
    P043f
    P2401
    P2402
    P2419
    All these codes pertain to "Evaporative Emission System Leak Detection Reference Orifice Low Flow"
    About two weeks ago I overfilled the gas tank put about 45L and I wasn't empty (gas tank capacity itself is 45L) so most likely some gas went to Evap Canister.
    I re-setted the codes but I'm sure they will be back.
  17. syscon
    syscon Member
    329
    43
    Edm. Alberta
    SOLVED
    I used a simple "electric duster" (picture enclosed) for 4-5min.
    Put the nozzle into a gas tank and I blow the air IN.
    I would not use any compressor (too much pressure). The fuel was somehow cleared from the evap canister. After the engine light and engine errors codes came only once (I think) and clearing them they never come back. I'm on my second gas tank and no error codes show up.
    In addition the gas pump did not triggering off the fuel pump spout.
    Simple procedure saved me about $1000CAD
  18. Mendel Leisk
    41,898
    If you're trying to squeeze as much in the tank as possible, go back to stopping at the first click. Don't run it low either: it's a mugs game seeing how far you can go on a tank.
    And yeah: sounds like your car is starting to drink oil. Check it frequently.
    What oil change interval are you using? The recommended oil change interval is 8000 kms, or 6 months. It's in the Ower's Manual Supplement booklet. Which if you're missing, can be downloaded here:
    http://s3.amazonaws.com/toyota.site.p01/toyota/manuals/OMS1012U/OMS1012U.pdf
    Here's an excerpt, from page 25:
    Note, both Oil & Filter Service and Maintenance Service include an oil and filter change. Confusing, but bottom line is: you're supposed to change the oil and filter every 6 months or 8000 kms.
    Note for anyone reading along: this is the Toyota Canada schedule; US schedule lets the oil and and filter go twice as long.
    #18 Mendel Leisk, Oct 28, 2018
    Starship16 likes this.
  19. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Oil change intervals after 24K km should be every 16000km or 12months (not every 8000km).
    And that is what I'm using every 16K km or once a year.
  20. Mendel Leisk
    41,898
    No. Again, both "Oil and Filter Service" and "Maintenance Service" include an oil and filter change: upload_2018-10-29_10-13-9.png
    The booklet is poorly written: it's deplorable that something so fundamental as oil change interval is expressed thus, but yeah, 3rd gen Canadian Prius oil change interval is every 8k kms or 6 months. For confirmation, the Toyota Canada interactive website:
    Maintenance Schedule - Toyota Canada
