Learned Something NEW about my Prius
Discussion in 'Gen 3 Prius Main Forum' started by iskoos, Oct 29, 2018.
  1. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    This maybe known to many of you but I found out this just lately...
    We all know (and many of us hate:)) That the ICE starts in about 15 seconds once the start button is pressed (with foot on brake).
    Well not if the gear is in Neutral "N". I discovered this by a chance while backing out of my driveway in the early morning hours. My driveway has enough incline to let the car roll back on its own when in Neutral.
    I was doing this in the morning and then shifting to "D" and every time I shift to "D", the car would start in that second. I was telling my self how perfect timing this is that every time this maneuver takes exactly 15 seconds for me. Because I was shifting to "D" and it would start in that second.
    I finally realized that it wasn't the perfect timing. It was because of the "N". ECU delays the ICE start till the car shifts out of "N". Don't know why...
    I tired it one day. I waited for about a minute in "N" while the car was cold. Engine didn't start. Then shifted to "D" and the ICE started immediately. It doesn't have to be "D". Any gear other than "N" will result in an immediate ICE startup (given the engine is cold).
    So why is this discovery a big deal (for me at least)? Because I sometimes move my car in my garage/on my driveway etc. and I hate for that ICE to start itself. Because once it starts, I will not turn it off (infamous knocking issue!..) before it goes through its cycle. It is painful for me to sit and watch my car burning fuel for nothing and causing mpg figures going down.
    *** I know "Mendel" has a 12-second counting method and then shutting it off for another 12 seconds(y) I used it a few times. It is just a bit stressful for me:) ***
    Really this is (Mandatory ICE start) I think the only ONE thing I hate about this car. Why can it not be stopped? It would have been so easy to make that "EV" button work when the car is cold.
    Anyways one more thing, if you ever use the above method I explained to prevent the ICE startup, you MUST power off the car while it is in "N" mode. If you press the "P" and then try to power it down (even very fast), it will start the ICE in that split second and everything you have done will be useless...:eek:
    Just sharing...
  2. hill
    8,786
    Welcome . . . to 2004
    Yeah, it's been that way since a long long way back . Some have gotten out of their car, left it that way, then overnight found their car in red triangle mode. The car won't start the ICe once it's in neutral - so when you're traction psck gets parasitically exhausted - you enter a truly special mode, that some (at least me) call SOL ... because you are then going to have to go to the dealership to bring the car back to life.
    #2 hill, Oct 29, 2018
    Sporin likes this.
  3. bisco
    51,823
    that's a pretty cool discovery, i have never heard it before.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The car can't start the engine in N.
    The car can't stop the engine in N.
    The car never charges the HV Battery in N.
    There is no regenerative braking in N.
    There is some speed where you are over-revving the MG/1 bearing in N. (low 40s in Gen 2, low 60s in Gen 3, low 80s in Gen 4)
    Some folks try to use a carwash that pulls your car through it in N, and the HV Battery goes flat. Do not use that kind of carwash.
    James1964 likes this.
  5. iskoos
    415
    254
    Orlando, FL
    Why would you leave your car in powered on state all night?
    If some folks don't know how to power off their vehicles once they leave, I don't have any recommendation for them. Sorry.
    What I said above is for those who would like to use it the way I described above. And they will not need to go to the dealership.(y)
  6. iskoos
    415
    254
    Orlando, FL
    I think you missed my point. This isn't to go around and spend time in "N" mode. It is just to move the car around (within a few feet to a few yards) quickly without starting the ICE.
    If you don't have any problem running the ICE and waiting for it to shut down (or you shut it down while it is running), You don't need to try it obviously.
    I just thought there might be some folks out there that would like to know what I discovered by a chance. That was it...
    Bay Stater likes this.
  7. Mendel Leisk
    41,273
    It IS stressful. The 15 second engine hiatus is very reliable, but oh boy as you count down the tension mounts, lol.
    Reminds me of Sonic SpinBall, when he's underwater, and time is running out...
    Bay Stater, Tideland Prius and iskoos like this.
  8. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    :LOL::LOL::LOL::LOL::LOL::LOL::LOL::LOL::LOL::LOL::LOL::LOL::LOL::LOL:
  9. iskoos
    415
    254
    Orlando, FL
    Well I got mine less than a year ago. So:)
  10. iskoos
    415
    254
    Orlando, FL
    I first typed "It is very stressful for me", then edited to "It is a bit stressful for me"
    Yes, it is Damn stressful:LOL::LOL::LOL:
  11. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    I have never had a problem in a carwash. If your HV is not on the bottom bars and your 12 Volt is good. Don't worry about it !!
    TelcontarOfBree, milkman44 and Sporin like this.
  12. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    I also stress when I want to back it out of the garage and not have the ICE start up. :mad:
    I'll try the shift to neutral method next time.(y) . Nice to know.:)
  13. Mendel Leisk
    41,273
    Huh, finally read carefully enough to understand. So I could put the car in "Ready" (one push of power button with foot on brake), shift to Reverse to start it rolling, then shift to neutral and coast with impunity, as long as I want, down my down-sloping driveway? Or do I need to go straight from Park to Neutral, then employ Fred Flinstone mode?
    Bay Stater and Grit like this.
  14. Bay Stater
    534
    771
    Central Mass
    I hope it's the former, not the latter. Don't want to cut a floor board hole. :ROFLMAO:
    Raytheeagle likes this.
  15. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
    Raytheeagle and Bay Stater like this.
  16. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    will the time reset if I go like after 10 seconds from rear to neutral?
  17. Prodigyplace
    12,521
    11,742
    Central Virginia
    Why not use EV mode for that? Or do you race down your driveway??
    kc5dlo likes this.
  18. Bay Stater
    534
    771
    Central Mass
    Can't use EV mode if the ICE is cold.
    Prodigyplace likes this.
  19. Mendel Leisk
    41,273
    Maybe EV mode is more often available in 4th gen? The rule-of-thumb with 3rd gen: if you need EV mode, it won't be available. I don't recall it ever being available with a cold engine.
    Bay Stater and Prodigyplace like this.
  20. Prodigyplace
    12,521
    11,742
    Central Virginia
    No.
    I remember enviously looking at a Gen 2 pull out of the parking lot in EV mode and my Gen 4 would not because it was "too cold" (below 68F, 20C) :mad:
    Bay Stater and Mendel Leisk like this.
