what's the bare minimum assembly for the HV battery to start and run prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by goodmania, Nov 1, 2018.
  1. goodmania
    goodmania New Member
    I try to fix HV battery. I try to test drive if the HV battery working correctly but I don't want to put everything together yet to save the time, I did not put nuts on each battery cells just orange connector and connected every connections but did not install the covers, I just put two volt to hold the whole battery, and try to see the car is running, but the car won't start correctly, I cannot shift to D or R. what's the bare minimum I need to do for HV battery to start the car correctly and run?
    51,843
    This may be a first. I’ll be interested in the answer as well. Be careful around high voltage!
    exstudent likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    You need to torque the nuts to 48 INCH pounds;).
    Otherwise you have no connection.
    #3 Raytheeagle, Nov 2, 2018
    JC91006 and bisco like this.
  4. bisco
    51,843
    That takes all the fun out of it:whistle:
    Raytheeagle likes this.
  5. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Well if time is no object, do one thing at a time until it starts;).
    But the nuts would be first on my list (y).
    JC91006, SFO and bisco like this.
  6. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Welcome to PriusChat!!
    What OBD2 codes are being thrown, as they will point you in the right direction.
    Not sure which two bolts you used to "hold the battery down", but the HV battery will need to be grounded to the chassis.
    JC91006 and Raytheeagle like this.
  7. JC91006
    JC91006 Senior Member
    16,762
    8,562
    You need to put all the nuts onto the battery modules. Without that, there's no connection.
    Be sure not to kill yourself when working with high voltage
  8. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    1) Competency.
    2) Laziness is counter productive, and may be detrimental to your health.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    There's an old joke about a half a glass of water. Optimists say it's half full, pessimists say it's half empty, and engineers say it's too big of a glass.
    The engineers who designed the battery had a reason for every part on there, and trust me -- engineers don't waste time and money on bling in the hybrid system because it would add unnecessary weight. Nothing is there just for looks. As @JC91006 said, it won't work if you don't tighten every fastener.
  10. RRxing
    RRxing Senior Member
    2,545
    1,821
    NEPA
    In the time it took you to post here and wait for a reply you could have put everything back together properly, be up and running, and not have to post here...
  11. strawbrad
    strawbrad http://minnesotahybridbatteries.com
    953
    1,007
    This sounds like the orange safety plug has not been properly installed. It's a common mistake for first time battery work. To install the orange plug, push it in, flip the lever up, and then push the lever straight down. It's that third step that trips up newcomers.
    As others have said, the case needs to be grounded to the car body. It sounds like the two bolts you installed took care of this. Of course all the nuts need to be installed and torqued to 48 inch pounds on every battery module. Plug in the computer connections and you should be good to go for a test run.
