Aftermarket Wheel Thread
Discussion in 'Prius c Accessories and Modifications' started by SSG S, Apr 27, 2012.
  1. edspecR
    edspecR Member
    136
    94
    Berkeley
    195 on a 6.5 is perfectly fine, in fact thats the recommended size. you'd have no issues running that wheel/tire combo, sounds like America's tire just wants you to buy new tires from them. you should have no doubts that it'll fit
  2. cyeremian
    cyeremian Member
    142
    27
    SF Bay Area
    I've had my wheels on since November of last year. They are 15 x 7. I swear I get better gas milieage because they are lighter than stock. Plus the car handles way, way, way better than the stock skinnys. See more information below.
    Wheel Brand Advanti
    Wheel Model 79B STORM S1
    Wheel Weight (preferably from a scale, but manufacturer weight is ok) My installer said 11.5 pounds per rim. I cannot find anything on the internet that says anything about weight though. I may not be looking hard enough. I haven't had them long enough to see if there are differences. Just on the ride home from work, I think I am getting a few miles better but it's hard to tell until I take a longer trip. Stay tuned.
    Size 15" x 7"
    Offset Offset: 35 Backspace: 5.375
    Tire Size Stock tires 175/65R15 There doesn't appear to be much stretching at all. Looks great.
    Tire Pressure Monitors My installer just used the monitors from my stock wheels. Works just fine
    Difference felt in ride quality (if any) no difference, I think the handling feels more planted due to the wider rims
    Price Paid $750 mounted balanced including tax. I used the same tires that I've had on the car
    Fitment Issues none at all.
  3. kinggupp
    kinggupp New Member
    Sfbay
    2016 Prius c
    There she is, on with no issues.
  4. cyeremian
    cyeremian Member
    142
    27
    SF Bay Area
    Looks really good with the rims.
  5. J Buck
    J Buck New Member
    Gettysburg, PA
    2016 Prius c
  6. william2018
    william2018 New Member
    2017 Prius c
    Can anyone let me know if this will work. I've got a 2018 Prius C. I have wheels that are 15X8 offset +20. I want to run a 205/50/15" tire. Will I have fitment issues ?
  7. edspecR
    edspecR Member
    136
    94
    Berkeley
    yeah, you'll rub unless you put your car on stilts.
  8. Victorynow1
    Victorynow1 New Member
    This is all new to me. I've recently replaced my 2012 Prius C tires and rims with aftermarket tires and wheels. My rear end bottoms out all the time now. What can I do to prevent this? Someone said something about putting a spacer
  9. Victorynow1
    I need some help with the rear end of my 2012 CE bottoming out after I replaced the stock wheels and tires with aftermarket. Can anyone help me out?
  10. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    We need to know your the size of the wheels and tires and necessary specs like offset.
  11. edspecR
    edspecR Member
    136
    94
    Berkeley
    define bottoming out? are your shocks hitting the bumpstops or are your tires hitting the fenders? shocks on stops = bottoming out, as is scraping car body to pavement. neither have much to do with tire/wheel choice. tires hitting fenders = rubbing, and then we need all the info aforementioned. unless you're bottoming out by slamming the fenders onto your tires, which in that case someone should have done more hw (and still considered rubbing)
  12. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
    Wheel Brand: Sparco (OZ Racing)
    Wheel Model: Trofeo
    Wheel Weight: Light, but I don't remember exact numbers
    Size: 16 x 6.5
    Offset: 37mm
    Tire Size: Toyo Extensa HP 205/50/16
    Tire Pressure Monitors: Yes, factory reinstalled.
    Difference felt in ride quality: Hard to say exactly. I did the RSR Down Springs at the exact same time. Everything combined is a much "sportier" feel than stock.
    Fitment Issues: Front has a slight rub and full lock under speed. (think U turn in heavy traffic, when you're trying not to get hit) Rear had a 1/4 panel rub on LARGE dips or bumps. A bit of trimming and a minor amount of rear camber added fixed it 100%. A 195 probably wouldn't have an issue.
    Mikalswrx02 likes this.
  13. bluekona
    bluekona Junior Member
    Oregon, USA
    '00-'01 MR2 Spyder Wheels
    Front 15x6 ET45
    Rear 15x6.5 ET45
    195/60R15 (all 4)
    Tanabe DF210
    2013 Prius C Three
    Brandon Most and edspecR like this.
  14. Issy Car
    Issy Car Member
    56
    48
    Vancouver Canada
    2015 Prius c
    So late to this party!!
    Motegi MR143 15x6.5 on 195/60 15 Michelin Premier A/S tires
    Lowered on Tanabe NF210 springs
    Darien Day likes this.
