Getting a P0ADC-226 | c1310 | c1259 After installing new battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mavi, Oct 20, 2018.
  1. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Is going overtorque a bad thing or neutral at best as long as nothing is broken? I'm fairly sure I went over rather than under, but will check with my new 1/4" torque wrench later today.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,264
    15,515
    Bay Area, California
    2019 Prius Prime
    Over torque can be just as bad. While you may not see any damage initially, the extra force on the connection can lead to it being stripped over time as the fastener is under stress.
    05PreeUs likes this.
  3. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    It's WORSE, because once the fastener breaks, you cannot "back it off 1/2 turn and run it".... LOL :whistle::p
  4. 05PreeUs
    1,097
    564
    MSP
    This matches up well with the "squeeling" sound the OP reported, sounds (no pun) like one of the HV relays is rapidly cycling. Were the relay nuts TORQUED? If not, you may have done internal damage to the #2 relay.
  5. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Nah that code is now fixed.. that was due to a half connected connector. It makes no odd noises after fully seating the connector.. my only problem now is the internal resistance levels of the modules.
