Help with dreaded p0aa6 code
Discussion in 'Gen 2 Prius Technical Discussion' started by OmaramO, Sep 26, 2018.
  1. OmaramO
    OmaramO Junior Member
    36
    Fremont CA
    Hey everyone!
    So one of my cars which has been driving fine for along time all of a sudden got hit with the dreaded p0aa6 code. I assumed one of the cells was leaking but when I opened up the battery case I found the main connections burnt and no cells leaking... not sure how to proceed from here any help is appreciated! P.S sub codes are 526 and 614. aPzqAxmzRTqBjM5VGwXTZA.jpg Q708AFggRLWSSlHXLrnUuQ.jpg
  2. DLC82SV
    DLC82SV Member
    241
    119
    That doesn't look good at all. I wonder what's causing all that resistance?
  3. OmaramO
    36
    Fremont CA
    I’m really not sure. I could definitely tell that someone has already worked on this battery before (missing bolts and cells with different numbers on them). Not sure if it was from someone putting the wrong bolts on these terminals or over tightening them (they were both stripped also).
  4. bisco
    49,388
    how many miles on her?
  5. OmaramO
    36
    Fremont CA
    210k
  6. bisco
    49,388
    i suggest the service manual, unless someone has a better idea.
  7. OmaramO
    36
    Fremont CA
    From what I’ve found so far I know p0aa6 is a isolated fault code which I’ve had happen one time before on my aunts Prius. But that one when I opened it up there was obvious electrolyte under one of the cells and I replaced it, cycled it, cleaned the case and it was good to go but this one is more of a mystery.
  8. bisco
    49,388
    can't the p0aa6 also be tranny or a/c?
  9. OmaramO
    36
    Fremont CA
    From my understanding I believe it can be a isolated fault anywhere in the hybrid system (battery, tranny, inverter). Could the resistance coming from the tranny or inverter cause the wire to burn like this? I just assumed it a had something to do with the battery because that’s where the burn was
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,194
    5,891
    Columbia, SC
    You can tell just by the photos that the lugs were never tightened. Oops, read a few more posts and it appears the poster may have loosened them. But he did mention they were stripped. If they were actually stripped, there's no way they could have been properly torqued. That would easily be the source of the arc/heat damage.
    The main lugs don't look to be severely damaged. A little cleanup and they'll probably be fine. I would try just installing a replacement set of main relays and correct fasteners. You may need to replace the lug on the white wire if it's significantly damaged.
    Should be a relatively easy fix.
    #10 TMR-JWAP, Sep 26, 2018
  11. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    The nuts look loose on the connections
  12. OmaramO
    36
    Fremont CA
    Yes you are correct this picture was taken after I tried to loosen them and noticed that they were just turning and going nowhere from being stripped. So today I changed both main relays and put two new nuts on the connectors and cleared all the codes. Unfrontunatly the same code came right back on after only 1 minute of the car idling.
  13. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Have access to torque app to see the traction battery info??
  14. TMR-JWAP
    6,194
    5,891
    Columbia, SC
    Another thought....how did you determine no modules were leaking? I've had several that had no visible leaks when the top cover was removed, but puddled crusties were under the modules in the bottom pan area.
    Raytheeagle likes this.
  15. strawbrad
    strawbrad http://minnesotahybridbatteries.com
    953
    999
    The 614 sub code shows that the leak is not coming from the battery modules. It's area starts at the battery terminals and continues to the inverter.
    https://attachments.priuschat.com/attachment-files/2018/09/154191_614_code.pdf
    OmaramO, davecook89t and Raytheeagle like this.
  16. OmaramO
    36
    Fremont CA
    I don’t have the torque app I use techstream to monitor the battery.
    I looked all around the connections on the bus bars and around the connections on the bottom of the case. I also flipped it upside down to see if I could find any corrosion.
    In this case what would you suggest doing? Should I just try to clean the battery terminals better?
  17. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Individual cells all look good then??
  18. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
  19. ericbecky
    ericbecky Hybrid Battery Hero
    4,369
    3,217
    Madison, Wisconsin
    Take time to buy an inch-pound torque wrench to properly tighten all the electrical connections.
    If bolts or posts are stripped they should be replaced. Else you risk a fire caused by arcing.
    Guessing the tightness when it comes to High Voltage connections is crazy.
  20. OmaramO
    36
    Fremont CA
    Thank you for the input! I should have clarified in the post but this was the first time I had opened the battery. Someone else had worked on it before. I torque all the 8mm on the battery to 50 inch pounds.
