Going to install a new 12v bat
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fartsalot, Nov 4, 2018.
  1. Fartsalot
    Fartsalot Junior Member
    35
    West of the Kansas Speedway
    When I install a new 12v (Optima) do I need to keep voltage on the system such as keeping the terminals connected to a 12 volt source. I assume my radio programming would be lost if not and what about my smart key? Do I push the little button thingy under the steering wheel and shut down the smart key.
    Curious about the right procedure and having the switch go smoothly.
  2. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Nope just swap it radio easy reprogram
  3. audiodave
    audiodave Active Member
    800
    272
    US
    It's good your clearing the memory. Hopefully your problems will be gone.
  4. Fartsalot
    35
    Thanks Guys,,,,, I got a optima located and will install this weekend along with a new factory pvc.
  5. bisco
    52,284
    you might have to reset the windows
    MickyMatter and Mendel Leisk like this.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Why did you choose the Optima ?
    They don't have a really good reputation for reliability.
  7. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Great choice, better than oem, check it for charge, chances are you will need to trickle charge it up to full before installing, clean the terminals and use dielectric to make a good or better connection.
  8. Mendel Leisk
    41,824
    You don't have to keep voltage supplied, but it will save all the volatile memories: radio presets, and possibly the window auto-up (if so equipped). One other thing: I sometimes intentionally disconnect the 12 volt when doing brake work, and subsequently I'll notice an odd engine rev-up, at the next maybe two start-ups, like the car's computers are recalibrating something.
    Lots of ways to supply 12 volt, what I did was get an OBD to 12 volt cord, purpose-built for this. It's an OBD plug at one end, albeit with only the 12 volt pins, and has the cigarette lighter style plug at the other end, which I plug into a 12 volt receptacle on my jump pack. the cord has an indicator light so you plug in first one end, then the other, to verify you have a good connection. Some cords have an indicator light for both ends, a little easier.
    Here's one example:
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    Dielectric grease is NOT a conductor.
    It is intended to be put on the OUTSIDE of connections to prevent corrosion without causing a partial short.
    It is NOT intended to be used between conducting surfaces.
  10. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Good point, it will squeeze out and protect the terminals, keeping them from oxidizing.
  11. cyberpriusII
    1,157
    1,822
    Mars Hotel
    As said, no worries about losing things -- except -- in some cases -- at least in our Camry, the computer lost the correct idle speed.
    Don't know if that happens with the Prius, it did not when I put in a new Prius battery five years ago.
    But with the Camry I ended up having to clean the throttle body, the MAF and letting the car idle for about 30 minutes in the driveway before the idle smoothed out.
    Personally, read enough stuff on here about Optima that I go for the Toyota TrueStart. The warranty is terrific, it fits perfectly and the price can usually be haggled down with coupons and/or begging/complimenting or otherwise "working over" the parts counterperson at the dealership.
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    The point IS.......that once you have grease inside a connection, you can never get it ALL out just by "squeezing".....and it might cause problems down the road.
    cyberpriusII likes this.
  13. Mendel Leisk
    41,824
    I'll look at how things come from the factory, consider that. Not saying it's always right, it could be they were cutting corners. I know, for example, the little nuts and screws on the car underbody REALLY should have been drenched in oil from the outset. Ditto for the license plate bolts.
    But anyway: the 12 volt battery termininals were clean and dry from the factory, so I keep them that way. Something I like to do though, is remove the battery, say around year three, brush the posts and clamps back to shiny metal, and reinstall.
    #13 Mendel Leisk, Nov 5, 2018
    05PreeUs and audiodave like this.
  14. cyberpriusII
    1,157
    1,822
    Mars Hotel
  15. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Obviously, any dielectric that doesn't squeeze out is filling empty space, which will now not oxidize, win-win.
    Simtronic likes this.
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    Bad assumption.
    That is not true.
    The film just gets thinner and thinner and never completely goes away......except maybe under EXTREME pressure and heat.
  17. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I just fitted a calcium 12v battery fitted perfectly Yuasa ybx5057 48Ah, calcium batteries are happy with AGM charging voltages. It comes with as 5 year warranty here
  18. sam spade 2
    7,035
    2,804
    2017 Prius c
    If you study up on the specs of your "calcium" battery, you should find that it really is mostly a conventional lead/acid design with a tiny bit of some calcium compound thrown in there somewhere.
    That technology/chemistry has been around LONGER than AGM.
    And in most common applications, an AGM battery is perfectly happy with a charging system designed for wet cell lead acid use. There really isn't THAT much difference.
  19. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I agree with you mostly but the calcium batteries live long on an AGM charging regime where as a standard wet lead acid won't last at the higher charging voltages. Calcium additive to the plates to reinforce them physically has been around for ages but the new batteries or calcium calcium as some call them are far superior. I know from seeing test results but you would have to speak to an expert as to the chemical changes they have made.
  20. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    No OEM suggests doing this and no battery manufacturer does either, both groups have spent more time and $$$ researching the best maintenance practices than the world of DIY'ers have.
    As a RULE, you NEVER EVER put a non-conductive material between two conductors that are intended to be "electrically bonded". There are products specifically made to be used in such applications, dielectric grease they are not.
