Sudden power loss on a Prius 05
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dxta, Nov 6, 2018.
  1. Dxta
    Dxta Senior Member
    1,940
    769
    Lagos
    A friend of mine called and told me his Prius suddenly stalled(gradually loss in power), while he was driving.
    According to him, he got someone with another Prius have the HV battery swapped from the working Prius to his own.
    His Prius didn't start. Eventually, they discovered each time they did the battery swapped, each of those batteries gets discharged within 5minutes.
    I have not being there to check it out yet.
    I'm thinking it might be the inverter system area.
    What do you guys think?
    Has anyone experienced this problem before?
    Codes were:
    P0a4b
    P0a09
    P0a0d
  2. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Do you have the 14 volts going to the 12 volt battery to keep it charged.
    Is there a hard bird battery actually charging
    did you try putting the engine inspection mode bypassing the Hybrid engine to see if it is the Hybrid engine or the battery and see if the engines working properly
    SM-G965U1 using PriusChat mobile app
  3. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  4. Dxta
    Dxta Senior Member
    1,940
    769
    Lagos
    I'm not referring to the 12v battery, but the HV battery.
    brdmb likes this.
  5. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    The Hybrid battery charges the 12-volt battery so I was wondering if the inverter was working and not loading down your Hybrid battery
  6. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
