Something weirdjust happen
Discussion in 'Gen 3 Prius Technical Discussion' started by Godzilla007, Nov 12, 2018.
  1. bisco
    52,398
    agreed
  2. Mendel Leisk
    41,923
    Yeah sorry, short attention span.
    If he pulled off the EGR valve and cooler, and thoroughly cleaned both, then that's that. I'm sure he would have done the pipe as well, it has to be removed, and cleaning it is trivial. Did he take any pictures, probably not? Did he say anything, what it's condition was, how the cleaning went? Maybe fish a little... :whistle:
  3. Godzilla007
    Godzilla007 Junior Member
    Phoenix
    He did say there was some build up but not to the extreme. What was the most crucial part was the spark plugs, he said those definitely needed to be changed and at the same time he did a compression check for each cylinder. With that being changed the misfire went away and car drive really good.
