Transmission noise
Discussion in 'Gen 2 Prius Main Forum' started by Alnilam, Aug 12, 2006.
  1. Alnilam
    Alnilam The One in the Middle
    760
    Carlsbad, CA
    I know I'm leaving myself open to ridicule by saying this, but a couple of times I've found myself moving with the freeway traffic at high speeds, especially in the HOV lanes where I don't want to be the bottleneck. I've noticed that at about 83 mph, if I add some gas, the engine/transmission makes a sound similar to what I used to associate with a slipping clutch. You know, the engine speeds up but the car doesn't seem to be getting all the torque. It does speed up, but this noise bothers me. Is something slipping, besides my brain?
  2. richard schumacher
    7,664
    1,044
    United States
    No. Prius engine RPMs are not directly related to road speed, and the engine needs to rev up to provide the necessary power through the electric generators and motors. For the same reason the engine will roar when going up a long grade at speed. It's normal.
  3. Alnilam
    760
    Carlsbad, CA
    <div class='quotetop'>QUOTE(richard schumacher @ Aug 12 2006, 09:18 AM) [snapback]302133[/snapback]</div>
    Thanks. That makes sense. In all other cars the ICE is just used to power the wheels. I forgot that in this one it also has electrical duties. It's a pretty smart transmission that can maintain a smooth ride while the engine is jumping around in speed.
  4. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    The fact that you're running the engine power output up that high
    to maintain 83 mph should, um, tell you something.
    _H*
  5. Alnilam
    760
    Carlsbad, CA
    <div class='quotetop'>QUOTE(hobbit @ Aug 12 2006, 10:56 AM) [snapback]302172[/snapback]</div>
    You got me...... :(
  6. qbee42
    3,077
    There is absolutely nothing to slip. The noise is just the ICE making more power.
  7. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(Alnilam @ Aug 12 2006, 10:09 AM) [snapback]302157[/snapback]</div>
    The Prius does not have a transmission in the traditional sense. It has a planetary gear power splitting device.
  8. jeromep
    jeromep Member
    827
    Eastern Washington State
    <div class='quotetop'>QUOTE(Alnilam @ Aug 12 2006, 01:53 PM) [snapback]302247[/snapback]</div>
    Yeah, me too Bob, I'm not sure just exactly what hobbit meant, but I'm fairly certain that it is either related to greater fuel consumption at high speeds or it is related to the engine RPMs going someplace.
    That is the important part to consider with the Prius, engine RPM always has to go someplace. It is either being directed to the wheels, or to the MG or, in most instances, to both. In that sense, we can also agree that there is no slippage, because the engine is physically connected to gearing which is in turn connected to electrical devices or the final drive.
