front Brakes on 2nd gen Prius disc and pad swap.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by terramir, Nov 14, 2018.
  1. terramir
    terramir Member
    319
    51
    Los Angeles
    Ok,
    Figure the following leave fob in apartment, use emergency key buy grease, use grease on bolts. Swap pads and rotors b4 greasing use brake cleaner. Anything I'm forgetting?
    Also I have obdlink lx anyway I can use that to bleed the brakes?
    terramir
  2. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Don't bleed brakes
  3. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    It computer control and you don't have a computer to do it
  4. Patrick Wong
    18,210
    6,511
    Disconnect the 12V battery, then you don’t have to worry about the fob or having the skid control ECU log DTC.
  5. Mendel Leisk
    41,824
    Have you had any problems with the rotors? Check their thickness and runout with a micrometer and dial indicator? I'd say rotor replacement is WAY overdone.
    I would recommend Permatex Anti-Seize for faying surfaces: pad backs, to shims, to caliper contact points. And Sil-Glyde Brake Lubricant for the caliper pins.
    I'd second @Patrick Wong 's guidance: just disconnect the 12 volt negative lead at the outset, and when everything is reinstalled, push the brake pedal multiple times to seat the brakes, reduce pedal travel, before reconnecting the 12 volt.
    Regarding "brake bleed", do you mean to just bleed fluid while pushing back the caliper piston, or a complete fluid replacement? Either way, the second gen Repair Manual does not give an instruction for bleeding fluid, or replacement, without Techstream.
    Third gen Repair Manual does have a non-Techstream instruction, uses a chicken dance to put the car in "invalid" mode, but I doubt it's applicable to 2nd gen.
    If you're considering a brake fluid replacement, maybe do your brake job, then take it in to dealership for brake fluid replacement?
    #5 Mendel Leisk, Nov 15, 2018
  6. terramir
    terramir Member
    319
    51
    Los Angeles
    anyway to connect the obdlink lx to tech stream?
    terramir
  7. bisco
    52,284
    you need a compatible windows laptop
  8. terramir
    terramir Member
    319
    51
    Los Angeles
    I got a windows laptop with bluetooth so that should work I also have a cable if necesary but it's a chap ebay one I figured the obdlink lx is better
    terramir
  9. bisco
    52,284
    could be, i'm not that savvy
  10. a_gray_prius
    2,927
    783
    IL
    I assumed you would need a MiniVCI cable with TechStream rather than whatever ebay OBD interface.
    I'm in the same boat though - have to replace rotors and pads and I'm leaning aftermarket since I don't think I'm going to keep the car for too much longer (258k miles on original rotors in a salt state, so it's time). I'm probably not going to bleed the brakes.
