C-Biscuit needs some alloy wheels...
Discussion in 'Prius c Main Forum' started by rosethornil, Oct 26, 2018.
  1. rosethornil
    rosethornil Member
    47
    30
    Virginia
    2016 Prius c
    I've been all over eBay looking for something that's close to original equipment (my personal preference) but haven't found anything that's affordable (under $400).
    Any suggestions?
  2. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
    OEM alloy's on Car-part.com range from around $100-$175 each in this area. You might be able to find a local yard that has a complete set and would do a deal on them.
  3. skayaks
    skayaks Active Member
    123
    106
    Massachusetts
  4. rosethornil
    rosethornil Member
    47
    30
    Virginia
    2016 Prius c
    Thanks so much for the info on Scion rims. Those look STUNNING! And your little "C" is the same color as mine.
    Woo-hoo!
    Now, hopefully, I can find Scion alloys and can get those old steel wheels off the car.
    #4 rosethornil, Nov 3, 2018
  5. Mendel Leisk
    38,219
    m.wynn, ztanos and skayaks like this.
  6. zen_
    zen_ Junior Member
    29
    Midwest
    2014 Prius c
    If Discount Tire is an option, they have a good deal for whee and tire packages on Black Friday. I got 15" alloy wheels with 195/60 tires with the same deal on the 4th of July for only $500 out the door after all the rebates, and it was a huge upgrade for the look and handling of the car.
  7. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    But you can save up to 10%!
  8. davidc83
    davidc83 Member
    113
    Scottsburg, Indiana
    2015 Prius c
    Call autobeyours.com. They salvage Priuses and may have some wheels. 812-752-5050
    SM-S327VL ?
    ztanos likes this.
  9. rosethornil
    rosethornil Member
    47
    30
    Virginia
    2016 Prius c
    Thanks for the replies. I am really yearning for some new wheels. I also need new tires, and hate to mount them on these steel rims.
    ztanos likes this.
  10. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Have you thought about plastidipping your current steelies? You can get any paint color you want, just about.
