Will Techstream work with my existing OBD-2 link?
Discussion in 'Gen 2 Prius Technical Discussion' started by tvpierce, May 15, 2015.
  1. tvpierce
    tvpierce Senior Member
    951
    882
    Maine
    2013 Prius v wagon
    I have an OBD-2/USB link I've used for other cars.
    Can I use it with Techstream, or do I need to get a new Mini-VCI from eBay/Amazon?
    Thanks in advance.
  2. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    You have nothing to loose by trying it. If it fails buy the VCI.
    John
  3. tvpierce
    951
    882
    Maine
    2013 Prius v wagon
    OK. I'll give it a try and report back.
    Thanks!
  4. Britprius
    5,194
    1,921
    Something often missed when setting up is on the opening page of Techstream. With the adapter connected go to setup then vim select. Then choose the adapter you are using. If your adapter is not shown it cannot be used. It does not need to be connected to the car for this step.
    John
    #4 Britprius, May 17, 2015
  5. Pinkbeetle
    Pinkbeetle Junior Member
    Tbilisi
    Has anyone tried using techstream with one of those Chinese Bluetooth ODB2 dongles?
  6. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    Actually not an off-shore one, but yes and DOES NOT SUPPORT.
