Anyone tried Valvoline Maxlife ATF?
Discussion in 'Gen 2 Prius Technical Discussion' started by kutcht1, May 23, 2015.
  1. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    Just was at the local Walmart getting engine oil and was poking around at the ATF and noticed that Valvoline Maxlife is listed to be compatible with the Toyota WS fluid. Has anyone tried this or anything other than the Toyota branded fluid in the transmission? Also saw that Aisin Warner and Idemitsu have a compatible fluid but I can only get that online. My local Toyota sells the WS for over $12 quart, just wondering as I need to change mine out. See the link to valvoline pdf.
    http://www.valvoline.com/pdf/maxlife_atf.pdf
    TomK
  2. Mendel Leisk
    41,826
    There's been a few brave souls trying alternatives. Something like this, so much riding on it: no way I'd use anything but the kosher fluid.
  3. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I assume Aisin Warner makes the Prius transmission. So I'd trust a fluid sold by them. Heck, they probably make (or at least spec) the fluid for Toyota.
    Personally, I wouldn't roll the dice with the Valvoline.
  4. Patrick Wong
    18,210
    6,511
    I agree, especially since the one Valvoline ATF is advertised on its website as being able to replace four Toyota ATF which have different viscosity levels.
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    My worry not with it as ATF per se, but as an electrical insulating coolant for the Motor/Generators. I doubt Valvoline tested it as an insulator.
  6. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    Well, as some of you say "I rolled the dice" on my 2008 with 281,000 miles and changed the ATF with the Maxlife. After probably hours of reading on "bobistheoilguy" website even with what most Prius owners say there is tons of info out there that even have oil change companies using the Maxlife in these transmissions with no KNOWN ill effects (yes I know). So how can Valvoline say it is compatible with both Toyota transmission fluids as they are different, good question. As I now don't think the WS fluid is as special as most think, I figured it would be a good "let's see what happens" since I already had the fluid from when I did a service on my BMW. I had no know info on the current fluid that was in but it came out pretty much black. Currently the car shifts flawless and will keep updating as the miles go up and hopefully don't kill the thing:ROFLMAO:.
    TomK
    Mzungu54, kerbear54 and bisco like this.
  7. bisco
    52,286
    at 280, you'll never know the cause of death.
  8. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    So you are saying it is on borrowed time? Don't the GEN2 CVTs have a really low failure rate? I know the miles are getting up there but for me this Prius version has been damn near bullet proof. I am not as seasoned as many of you but also not green on these cars. Also know that anything fails if not taken care of and even more when ignored. Just read way to much about the Maxlife on that oil site and said why not.
    TomK
  9. Mendel Leisk
    41,826
    There's plenty of alternate transxle fluid "support groups" here, folks that'll high-five and back-pat you for going with something else. The other fluids may be ok, who knows.
    I just figure: Toyota is very adamant about using Toyota ATF WS, cautions that using anything else could damage the transaxle, so why argue? There's a phenomena I guess, when someone tells you it's really important to zig, you want to zag.
  10. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    If I remember in my manual is states to use Toyota WS or equivalent (I think or compatible) fluid. So whatever equivalent means we don't know. As with any other manufacturer they want to sell you their fluid. Since the CVT is still new technology, users don't know much of a track record and are somewhat afraid of using anything else. I used Castrol ATF in my 2002 and drove 40,000 miles or so with it without trouble. I just thought is was strange that most Prius users aren't using other fluids other than the Toyota fluid. Just thought I would follow-up with this question I had over 3 years ago when I bought my first GEN 2 which I did use the WS fluid in.
    TomK
    SFO likes this.
  11. Mendel Leisk
    41,826
    I set out to prove you wrong, but you are right, from the 2nd Owner's Manual:
    Still, in the third gen Owner's Manual, they change it, no more mention of equivalent, and a warning:
    Maybe due to more experience? Who knows, but I figure play it safe.
  12. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    I believe in the US there is a law that prohibits a manufacturer from making a sole source fluid for any car. That’s the reason for that disclaimer.
  13. bobodaclown
    bobodaclown Member
    216
    72
    I'm using it and have over 60k miles. No issues.
    kerbear54, kutcht1, edthefox5 and 2 others like this.
  14. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    Nice bob! I assume the Maxlife ATF is in your 2009, how many miles on the car?
    Mendel, that is interesting that it was changed when I swore in my manual it has (WS or equivalent). Could be an oversight or nothing at all. I did read that there are oil change chains doing ATF services that use the equivalent fluid and not the WS. I would think that would be risky for them if they read the manual that has the warning. Good info.
    TomK
  15. TomB985
    TomB985 Member
    137
    68
    Isanti, MN
    I changed mine with MaxLife two weeks ago, and I'm not worried.
    It's listed as equivalent to the Toyota WS, and the Prius transaxle uses it for a far simpler purpose than most conventional automatics. There are no hydraulics or solenoids to foul, it's simply a glorified gear lube to my knowledge. It seems that Prius transaxle failures are rare even when neglected, so fresh fluid that meets the specs should be fine. Valvoline has recommended this fluid for the Prius for years, if there was an incompatibility we would see numerous failures by now.
    BuckleSpring, kutcht1 and edthefox5 like this.
  16. TomB985
    TomB985 Member
    137
    68
    Isanti, MN
    Just saw your location. Howdy, neighbor!
  17. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    They love Maxlife over at Bitog. Lots of Prius running it with no issues at all. They despise WS there though lol.
    Our trans is a manual gearbox which would probably run on anything. Its a fantastic piece of engineering really.
    The only question is how high a quality GL4 lubricant you desire. I personally have been running Redline D6 for 11 years and 100,000 miles with excellent UOA's.
    There's some UOA's in the transmission sticky.
    TomB985 likes this.
  18. bobodaclown
    bobodaclown Member
    216
    72
    132k on the Prius, about 4k ago changed our the pump for the inverter coolant loop. Now replacing the brake accumulator. That was a big hit to the wallet about $1800.
  19. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    On my transmission I switched to Maxlife I pulled the unit with 290,000 miles and shifting as it should. Engine had a piston crack and replaced both units with low mileage ones. So not many miles to report on the CVT fluid change from Toyota WS.
    edthefox5 likes this.
  20. Mendel Leisk
    41,826
    Well it doesn't "shift", but I assume it smoothed out.
    Was that the first fluid change? I'd speculate you'd have a similar improvement if the replacement fluid was the Toyota spec'd.
