What does it means
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by fssalfi, Nov 30, 2018.
  1. fssalfi
    fssalfi Junior Member
    24
    karachi
    What should I do Screenshot_20181130-151519_Gallery.jpeg 20181130_144429.jpeg
  2. alanwagen
    alanwagen Member
    122
    79
    FORT WORTH
    2018 Prius
    You will have to translate for us, thanks
  3. striker54
    striker54 Junior Member
    PT
    Active
    Can't find the first character of the second line in Google translator but it's something like this:
    Hybrid System Check
    Please stop
    Edit! (now 100%sure)
    It's:
    Hybrid System Check
    Please stop in a safe place
    #3 striker54, Nov 30, 2018
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Google translate can help ;).
    Could be anything from a low battery in a key fob to some thing more serious.
  5. Prodigyplace
    12,682
    11,833
    Central Virginia
    It means you bought a Japanese Prius that does not display other languages. ;)
    It also means it is lonely and wants you to find a Japanese-speaking friend.
    Raytheeagle likes this.
  6. bisco
    52,398
    take it to a dealer or hybrid specialist with a prius aware scanner like tech stream to have the trouble codes read, then post them here.
    #6 bisco, Nov 30, 2018
  7. Mendel Leisk
    41,923
  8. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Very helpful on a Friday (y).
  9. fssalfi
    24
    karachi
  10. Mendel Leisk
    41,923
    The frustrating thing: that tells you almost nothing, just that there's a problem. You will need to get codes read for more information. Does the car drive ok; do you notice anything unusual?
  11. fssalfi
    24
    karachi
    Everything seems to be fine and this stops coming automatically but on my after Mkt head up display obd2 shows 648
  12. fssalfi
    24
    karachi
    Actually I am in Pakistan karachi so here comes only Japanese prius
  13. bisco
    52,398
    worthwhile to check your battery cooling fan and intake grille, while waiting for diagnostic codes
  14. fssalfi
    24
    karachi
  15. bisco
    52,398
    doesn't sound like tech stream
  16. bisco
    52,398
    make sure your gas cap is tight
  17. Mendel Leisk
    41,923
  18. bisco
    52,398
    '4th gear not working on aerostar transmission'
  19. fssalfi
    24
    karachi
  20. bisco
    52,398
    techinfo.toyota.com
