Struggling to hit / maintain 55mph
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by usdm_b18, Dec 5, 2018.
  1. usdm_b18
    usdm_b18 Junior Member
    First off - I'm really sorry that my first post is a request for help.
    I was driving home this evening; and noticed a higher than normal degree of rolling resistance/drag on the car; similar to what you'd expect with a flat or near flat tire. I tried to get the car up to speed (45-55mph); however the throttle resistance became even greater. Further when I got up to 55+ mph; the transmission (or whatever it is we have) would seem to upshift resulting in no ability to accelerate; and a low drone sound. I did notice that even at low speeds there was a good amount of rolling resistance with even very soft acceleration; resulting in the miles/gallon indicator down around 20-22mpg.
    A few additional bits of information:
    -I did drive the car into the office around 12 hours earlier, with no problems
    -There has been a bit of a rattling sound coming from under the car which I suspect was a loose heat shield
    -the car has 145K on it
    -I checked oil; and it looked OK, last change was +/-4000miles ago
    -I didn't notice any drips from under the car
    -original batteries
    -no warning lights
    I'm going to take the car in tomorrow morning to my mechanic; however was hoping to get a few pro tips on what it may be, prior to walking in blind.
    Thanks in advance!
    #1 usdm_b18, Dec 5, 2018
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    You say it felt like a flat tire, so what was the pressure of each and we’re there any that were low?
    Any dragging brake pads (are the center of the rims warm)?
    Any change in gas or octane?
    Any recent maintenance or damage to your Prius?
    usdm_b18 and Pluggo like this.
  3. usdm_b18
    Thanks @Raytheeagle; pressure in tires looked good - I didn't test them, however based a solid eyeballing, nothing out of the ordinary.
    Same old Costco gas;
    Not sure about dragging brake pads; however I doubt it - there was a solid rattling when I got up to 50-55 mph; and the tranny up shifted; both which seem to be un-related to brakes.
    No recent maintenance aside from the oil change; an no new damage (door dings etc).
    Raytheeagle likes this.
  4. fuzzy1
    10,714
    This has snagged me on two past cars (shop repair error on one, repeated sticking pads from corrosion on the other), so is something I'm quite watchful for now.
  5. usdm_b18
    Thanks @fuzzy1 ; I'll double check tomorrow AM and report back!
  6. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Catalytic converters can clog and severely limit the power of the ICE. Maybe the rattling was a rusted out portion of the cat coming loose and blocking the rest.
  7. Mendel Leisk
    42,358
    Just to clarify: does that include original 12 volt battery? If so, wouldn't hurt to replace that.
    I'd second the various brake suspicions. And the suggestion to feel the rims immediately after a drive; see if any feel particularly warm.
    usdm_b18 likes this.
  8. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
    I agree with the brake comments, make sure that the park brake is fully released, also.
  9. Robert Holt
    Robert Holt Senior Member
    1,313
    890
    The above are likely culprits, but could I add one more. When my wife hung a bag over the right side of the gearshift lever in our Gen 3 hatchback, that caused it to slide right and engage “B” or braking mode , during which I experiences abnormally low mpg, abnormally high resistance to acceleration, and abnormally quick braking with I let off on the throttle. You seem to have some of those symptoms and for me it came on rather quickly and unexpectedly. So you might want to check that you (or miscellaneous objects) have not unintentionally engaged that “B” mode. (PS: it does show up as a highlight on the “B” on the MFD, but I just never noticed that subtle change in highlighted transmission mode until after a Priuschat member had figured out what my problem was.)
    Good luck!
  10. Greenteapri
    Greenteapri Active Member
    330
    388
    Cypress
    My money is on a clogged cat. Any oil consumption?
  11. usdm_b18
    Thanks @FuelMiser
    Actually just as a quick update; no word back from my mechanic. Fortunately we have an extra car; so I'm not in a rush to get the prius back.
    The cat coming loose sounds like a very real possibility; as I've had a bunch of rattling coming from the bottom of the car. I thought it was a heat shield however it very well could be the cat.
    What does "ICE" stand for?
  12. usdm_b18
    PS: Thank you all for the suggestions. Very much appreciated. I'll update once I have a resolution! :)
  13. Greenteapri
    330
    388
    Cypress
    ICE = Internal Combustion Engine
  14. FuelMiser
    1,349
    929
    Monument, CO
    Internal Combustion Engine. Thanks for following-up...
  15. usdm_b18
    Afternoon all -
    Got my car back :) Mechanic ended up checking the cats which were ok; however the 12v was the problem.
    I ended up doing ignition coils, tranny fluid; and spark plugs since I was there.
    Car runs like a camp.
    Thanks @FuelMiser @Greenteapri @Robert Holt @Mendel Leisk @scona @Raytheeagle for your insight on this one :) Happy holidays!
    scona, Raytheeagle, mjoo and 2 others like this.
  16. bisco
    52,863
    congrats!
    12v, why didn't't i think of that (n)
  17. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Must not have read your own signature :p.
    scona, RMB, bisco and 1 other person like this.
  18. scona
    scona Active Member
    225
    207
    2013 Prius v wagon
    Don't you just hate those "curve balls"?
  19. padroo
    padroo Senior Member
    2,763
    2,253
    What about the noise? I didn't see anything done that fixed your noise problem.
  20. usdm_b18
    So seems like I was too quick to claim victory on this one. I think I still need to do the cat. Which is where the rattling is coming from
    padroo likes this.
