Why does the MFD update so slowly?
Discussion in 'Gen 2 Prius Main Forum' started by darkecho, Aug 18, 2006.
  1. darkecho
    darkecho New Member
    60
    I would assume that it should be fairly easy to change the refresh rate of the MFD, I cant think of any reason why they(Toyota) would be limited in getting the MFD to go faster. I imagine that they just didnt want people getting too distracted with it if it update faster and was jumping around so much... but I think for us trying to get better mileage, having a quicker MFD would be nice because it wouldnt lag when showing us whats going on...
    anyone know if theres an easy way to change the refresh rate? or why its slow?
  2. gordonr
    gordonr Member
    117
    Massachusetts
    As has been described here before, the MFD is only a crude approximation of what is really going on. Beyond update speed, I'd first like it to actually show a much more accurate approximation of the HSD operation. As an example, much of the time I can be gliding (foot completely off the gas or brake pedals) to a stop from the 30 to 35 mph range with the MFD showing only recharge with the ICE off, and when I come to a stop the ICE is running as plain as day. Faster updates of inaccurate information isn't all that useful.
  3. darkecho
    darkecho New Member
    60
    Does CANview fix the problem of inaccurate information?
  4. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    <div class='quotetop'>QUOTE(gordonr @ Aug 18 2006, 09:33 AM) [snapback]305375[/snapback]</div>
    I too would like more information to be displayed on the MFD and the 3 second update rate is a bit slower than I would have designed, however I would dispute that it is inaccurate regarding the ICE state.
    In the example you quote the ICE is idling and not providing electrical power so the display is accurate. It does not attempt to indicate whether the ICE is running, only whether it is providing power.
    I don't know why but there seems to be a speed threshold that you have to hit before the engine shuts down quickly - I suspect it is to avoid excessive stop-starts of the ICE.
    I usually pulse up to about 38MPH before the glide and the ICE shuts down as expected, if I pulse to a lower speed then the engine will keep running until a few seconds after I come to a complete stop.
    kevin
  5. Renocat
    Renocat Member
    363
    Rochester, NY
    sheesh...when I read the title I thought "must be some New Yorkers that can't wait 3 seconds for the screen to update" Imagine my surprise when it was left coast folks.
    Now before anyone flames me...I am an uptight, impatient, type A New Yorker myself. I just happen to be a little further upstate. :lol:
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(darkecho @ Aug 18 2006, 01:06 PM) [snapback]305440[/snapback]</div>
    Yes, it is very fast to update.
  7. amitandrima
    amitandrima New Member
    24
    very short refresh times will end up looking like noise and it might not be easy for the driver to register data from a continuosly varying display. I think 3 seconds is good enough for the reading to be steady while the data is registered by the driver and yet not too far from being instantaneous.
  8. RichBoy
    RichBoy New Member
    189
    Im happy with the MFD as it is now.
  9. Cully
    Cully New Member
    Colorado
    It is possible for it to update much much faster but you will only get 28 mile to the gallon.
    Matt
    Denver
